what are the symptoms if my main relay is going bad?
Old 08-04-2009, 05:54 AM
949's Avatar
Default what are the symptoms if my main relay is going bad?
i was curious what kinds of problems will show if the main relay starts to go bad.
949 is offline
Old 08-04-2009, 06:25 AM
dephtone's Avatar
Default Re: what are the symptoms if my main relay is going bad?
Car won't start after parked for just a minute.
Car won't start when hot outside. Fuel injected PGMFI models only
Car starts but quickly dies as the rpm shoots to 1300 rpm.
Once started the car won't stall.
the symptoms return after shutting off the hot engine
No humming sound from the fuel pump the moment the ignition switches ON.
No click sound after the ignition key turns
10-15 of waiting and the car pushed to a shade will usually start.
http://techauto.awardspace.com/mainrelay.html
^ Great info on repairing the main relay and or everything you need to test yours out or even by-pass it.
dephtone is offline
Old 08-04-2009, 06:47 AM
949's Avatar
i think the first 3 sound just like whats going on with mine.
the 4th one you listed doesnt make sense to me ?
thanks that really helps me out.
i think ill just buy a new one.
949 is offline
Old 08-04-2009, 06:48 AM
sde780's Avatar
take yours out & resolder it, much cheaper
sde780 is online now
Old 08-04-2009, 07:03 AM
dephtone's Avatar
Meaning that the solder contacts have melted onto another part of the board which keeps constant power going to the board instead of the power leaving when you turn the ignition off.
Re-soldering your old one > 45 bucks for a new one. The site I listed shows you everything to do to resolder it and what the connections should look like when you open it.
dephtone is offline
Old 08-04-2009, 07:53 AM
949's Avatar
ok, i guess i have plenty of time right now. i can give it try.
949 is offline
Old 08-04-2009, 01:49 PM
949's Avatar
just finished it. ill be testing if it changes behavior.
i removed all the old solder on each of the contact points.
then i gave it a ton of soilder on the top of each point.
949 is offline
Old 08-18-2009, 07:52 AM
palmbayeg's Avatar
Ive had simular problems like this and i am planning on resoldering my main relay as well. I was just curious what your turnout was?
palmbayeg is offline
Old 08-19-2009, 05:52 AM
949's Avatar
i dont think i noticed much of a difference. im still having problem starting up.
949 is offline
Old 08-19-2009, 07:05 AM
EFB055
~sp33~'s Avatar
Good post.
What are your symptoms. Is it just cranking for a long time before starting?
~sp33~ is offline
Old 08-25-2009, 04:47 PM
New User
alltech_Si1via4's Avatar
Mine is acting the same way..after I replaced the main relay it started fine once and ran. Then it shut off and would only crank but not turn over?? And it doesnt struggle before it dies.
alltech_Si1via4 is offline
Old 08-25-2009, 07:31 PM
ed4_civic's Avatar
I could remove my main relay and tap on it a couple time and my car would start right up and that's how i knew it was the main relay i could actually feel it click in my hand
ed4_civic is offline
Old 05-01-2013, 02:03 PM
Hiboost 2.0's Avatar
i kno this is a 09 post but with a bad relay would the pump stop working .. or after the car dies no humming after the first turn of the key?
Hiboost 2.0 is offline
Old 05-08-2013, 10:43 PM
949's Avatar
not sure. maybe take a video and show us what you got going on.
949 is offline
Old 05-09-2013, 11:24 AM
Z0831xiz's Avatar
my car has problems too. i switch to ignition and it just cranks and cranks and cranks. then it slowly starts to stutter like barely getting fuel then slowly a little more then it cuts on... and when I'd break harsh on. stop sign . it just shuts off...
now it won't turn on at all will just crank and crank...
if any help please do!!
Posted from Honda-tech.com App for Android
Z0831xiz is offline
Old 06-13-2013, 01:46 PM
CXHBumpin39's Avatar
I have the same issue with mine..
CXHBumpin39 is offline
Old 06-13-2013, 04:34 PM
EFlovin''s Avatar
Are you guys getting spark? Check possibly
EFlovin' is offline
Old 06-13-2013, 07:22 PM
I had spark on every plug
Old 06-13-2013, 07:42 PM
Z0831xiz's Avatar
as do I. but I believe my problem might be my timing belt/chain. its lose on one side. tight on the other.
Z0831xiz is offline
Old 06-14-2013, 10:48 AM
POPLERO's Avatar
bump as this is some good info to kno
POPLERO is offline
Old 06-14-2013, 08:41 PM
Purfect's Avatar
When my main relay went bad. .My car slugged at the start. then started to slug more and more.. till i got tired of the fact that it might not start took out the main relay smelled it (smelled burnt) Bought a new one. fixed the problem.
Purfect is offline
Old 06-14-2013, 08:58 PM
Z0831xiz's Avatar
I tried 3 relays. including my own.
1 different ecu mpfi obd0 integra pr4 ecu.
changed my injectors to d15b7 then to another set from eBay I bought meant for d16a6.
changed fuel filter. new.
I hear fuel pump hum kicking in.
I tried hand over manifold with Carb cleaner inside.
started but then died was idling during process.
and I noticed my timing belt is sorta loss by my thought it should be really tight. so I'm trying that next.
so far nothing has worked.
any ideas would be great!
Z0831xiz is offline
Old 06-14-2013, 09:46 PM
Purfect's Avatar
Your car isnt starting?
Purfect is offline
Old 06-14-2013, 10:14 PM
Z0831xiz's Avatar
nope I changed or check all those things still doesn't start
Z0831xiz is offline
Old 06-14-2013, 10:17 PM
Purfect's Avatar
Whats the start sound like.. or lack of start?
I mean does it slug, just clicks? i mean the sound helps quit a bit.
Purfect is offline
Quick Reply: what are the symptoms if my main relay is going bad?
