Radiator fan not working while driving
Old 08-09-2009, 10:51 AM
New User
clair's Avatar
Default Radiator fan not working while driving
The radiator fan in my 94 accord seems not working during drive. I have to make frequent stops to cool down the engine. I am puzzled that everytime when I turn off the engine, the radiator fans starts to work. How can I fix that? Thanks a lot!
Old 08-10-2009, 09:30 PM
New User
Bullies4u2's Avatar
Default Re: Radiator fan not working while driving
my 96 accord ex with f22b1 vtec does not seem to run the fan either, but it does not run above half way on the temp reeding. so ill watch what help you get & maybe ill learn something myself
Old 08-10-2009, 11:01 PM
alkoholikwun's Avatar
check the fan switch and/or thermostat
Old 08-11-2009, 01:06 AM
YeuEmMaiMai's Avatar
the fan will not run when the car reaches between 38-42mph below those speeds it should run as needed
Old 08-12-2009, 05:23 AM
96redexcivic's Avatar
check your fan for a quick check may be it's sticking, turn the a/c switch on and check if both fan comes on, also turn it with your hands to see if it's free wheeling good not sticking, and i will check your cooling temp. sensor for the fan and or relay might be sticking. good luck.
Old 08-12-2009, 06:16 AM
7520's Avatar
I have a 1992 accord, my fans both come on with the a/c, and both even work sometimes when the a/c is off. Neither fan works when I turn the car off. Is that a sensor? If so, where is it located?? tks
Old 08-12-2009, 07:37 AM
Icon6 Re: Radiator fan not working while driving
Fan coming on after you turn off vehicle is normal for alots vehicle, the cooling temp. sensor is located near the thermostate should have two wires connector, but, I think I will check the thermostate maybe is bad (sometime sticking) change it, it's only couple bucks.
Old 08-12-2009, 09:24 AM
SFWD 1934's Avatar
Check the relay that is in the engine compartment fuse box. It is either number 20 or 21 in the diagram here:
http://www.hondapartsnow.com/Page_Pr...(Engine%20Room)
Jason
Tdawg_1993
06-30-2015 04:33 PM
Mrflip99
05-24-2015 09:23 PM
automan12
06-07-2014 04:26 AM
SpoonREVS
01-24-2006 05:42 PM
Quick Reply: Radiator fan not working while driving
