fast idle valve
Old 06-18-2009, 02:49 PM
eglude's Avatar
Default fast idle valve
so i have a 95 civic hatch with a d15b, i picked up a p32 intake manifold (d16z6 manifold) i go to hook everything up and the hose that goes from the bottom of the fast idle valve has no where to hook up on the intake manifold. this **** sucks. how do i go about fixing this problem? thanks in advance
Old 06-18-2009, 03:45 PM
eglude's Avatar
Default Re: fast idle valve
bump for help
Old 06-18-2009, 04:08 PM
D16SiHatch's Avatar
it starts at a L shaped hose at the intake manifold, and from there it moves through a metal tube to another hose which then goes to the inlet of the fitv. after leaving the fitv it goes to the iacv. once leaving the iacv it drops down and connects to the coolant pipe on the back of the block.
Old 06-18-2009, 04:35 PM
DjGuamstyles's Avatar
Nice diagram above. I heard, some drag racers bypass the FIT-V so the intake manifold temperature is lowered.
Old 06-18-2009, 04:44 PM
apexi_rsx's Avatar
yes thats what i would do because its pointless if u live in warm climates. just by pass the tb and run the lines to ur iacv. ebay acually makes block off plates b/d/f/h all fit
Old 06-18-2009, 04:58 PM
eglude's Avatar
thanks, this is going to help a lot! where did you get this diagram from?
Old 06-18-2009, 05:44 PM
civic_driver's Avatar
probably from the service manual
Old 06-18-2009, 09:34 PM
D16SiHatch's Avatar
i cropped out a picture i retrieved from AllData. I have a dealership login :D
then with the help of mspaint i added the awesome red lines and numbers lol
Old 09-14-2012, 11:53 AM
GSRicky37's Avatar
This is so helpful I just did the exact same thing but my throttle cable doesn't mount right so it either to tight or too loose. Why?
mayfly
13
06-02-2010 01:25 AM
illprelude
07-11-2008 05:04 AM
RiversideS13
07-18-2007 11:08 AM
egerdahl
07-28-2005 06:30 PM
importimage
06-14-2003 10:46 AM
Quick Reply: fast idle valve
