Radio Reset code
Old 04-26-2009, 08:03 PM
NubImports's Avatar
Default Radio Reset code
ok pulled the wrong fuse in my accord! need the code to get it to work were is the code located at?
Old 04-26-2009, 11:43 PM
aasaa666's Avatar
Default Re: Radio Reset code
I dont know what yr accord you have but some dealers put the serial sticker hidden around and on the glove box. some head unit can give you its serial number buy holding the 1 and 6 key, then push the on button/****. if none of that works, then you have to removed the unit and look on the label for the serial. Last you go to the dealership to prove you are the owner of the vehicle and then can try find the code for you. If it is the back up fuse that you pulled, from under the engine, please remember to perform the idle learn procedure.
Old 04-27-2009, 12:19 AM
4gen5thtime's Avatar
You can call the dealer with the vin of the car the stereo came from and they will give you the code for it. Some times they want you to go in though.
Old 04-28-2009, 11:11 AM
notAdiesel's Avatar
https://radio-navicode.honda.com/
this worked for my 00 accord, but i had to use the info from the guy i bought it off of, who i think was the original owner
monkeymac
11-17-2013 05:51 AM
BigDanTFM
06-08-2012 08:46 AM
sneaks
04-22-2011 11:25 AM
juevi (old)
05-23-2006 05:15 AM
Quick Reply: Radio Reset code
