Fuel system cleaner
Fuel system cleaner
Saw this at H and A, BG 44K Fuel System Cleaner.
Thought it'd be pretty cool and useful.
Has anyone used this product before??
When's a good time to use it, when isn't it?
Also heard it's pretty much like 'sea foam' so you can't use it more than once for like the cars lifetime, is this true? answers and advice please, thanks!
if this helps, my car is 9 years old, with 70k miles.
Re: Fuel system cleaner
Wouldn't hurt. The injectors aren't the only thing in a fuel system. Its a maintenance thing that can only do good. Personally have never used it in my car but have done it to several cars at previous jobs and always clears out quite a bit of carbon build up.
**** that "cleans fuel injectors" is bullshit.
Injectors are self cleaning, they dont get "clogged" anymore.
I've heard some controversial information about seafoam though...the **** will eat your valve stems if you use too much of it and/or dont change your oil immediately after you run it.
Lucas is some good ****.
Given a choice, I will never use Chevron again.
Wow, Fuel injectors are NOT self cleaning, have u ever took out a fuel injector? they have a little filter that filters **** that the main fuel filter does not capture. over time those filters get clogged and will cause slight miss fires. fuel injector cleaner will eat that stuff up and fix it.
Lucas fuel injector cleaner seems like oil to me it sux.
Preston Fuel Injector cleaner ALWAYS will stop my car from shaking if i go more than 5000 miles without it and i put it in and within 200 miles it idles perfect !
Those are the only 2 injector cleaning stuff I've ever used. Lucas is a good top Cyl lubrication product but not so good on cleaning injectors. not from my experiences which have been used several times and im never satisfied till prestone come in.
you guys ever heard of the old ATF trick? of putting a quart of ATF in you gas and it supposedly cleans your ****.
and dude...go to school.
I've heard some pretty good things about UTI, only heard **** about WyoTech though. my friend calls WyoTech the biggest disappointment of his life.
I'm enjoying it, I know thats for sure. ya know what they say..work a job you love, and you never work a day in your life..thats what I lookin forward to once I graduate.
dam, well I've loved cars all my life and love being around them so i know for dam sure it wouldn't be a disappointment in my life lol. and ya i heard of wyotech also.
