Torque specs for the Harmonic Balancer.
Old 04-15-2009, 10:59 AM
TravisCadello's Avatar
Default Torque specs for the Harmonic Balancer.
Ok, YES, i have serched. but I found 85ft pound and 130ft pounds and other people just say tighten it and the engine will tighten it as u drive. so i need a firm answer because i changed out my Block just because my other one came off and broke the threads.
Its the Big pulley. i need to know how to tight to put it. i tightened it real hard untill i felt my tranmition about to break with it in 5th gear and the brakes smashed. it this good enough or is it gunna come off down the road?
Old 04-15-2009, 11:00 AM
Default Re: Torque specs for the Harmonic Balancer.
oh its a D15B block and Y8 head.
Old 04-15-2009, 11:08 AM
New User
Eclivic's Avatar
134 lbs and apply oil to the bolt threads
Old 04-15-2009, 11:17 AM
sde780's Avatar
It's fine the way you did it. I hand tightened mine, drove for a couple weeks and it's fine
Old 04-15-2009, 11:34 AM
apply oil to the threads? for what is loctite better? i just put it on but if i need oil let me know ill take it back off. i have a impact wrech the size of my head and 50lbs !
Old 04-15-2009, 11:59 AM
New User
Eclivic's Avatar
oil is just to help heat resistance with 134 lbs
Old 04-15-2009, 12:18 PM
will i need to put some on or no?
Old 04-15-2009, 12:43 PM
New User
Eclivic's Avatar
if the bolt is already on then dont worrie about it
L_U_D_I_AAccord
08-24-2016 08:10 AM
HiProfile
01-21-2007 05:12 AM
realis9
01-07-2007 08:35 AM
2ndgenteg-md
09-30-2002 05:04 AM
Quick Reply: Torque specs for the Harmonic Balancer.
