car jerks
Old 11-05-2008, 12:10 PM
Boostn B20's Avatar
Default car jerks
previously i had this problem where my car only jerk from 1500-about 1700rpm though 1-3 gears, that mysteriously went away. now im having an issue where it jerks while im driving. i can take off fine, go thru all gears, then about 5 mins. driving it will start jerking back and forth, almost like it's starving for gas. i have fuel. i know how to drive, what could this be?
Old 11-05-2008, 02:00 PM
redcoats1976's Avatar
sorry,thought this was a thread about people that dont like hondas...
Old 11-05-2008, 02:58 PM
slacks's Avatar
Default Re: car jerks (Boostn B20)
i think you mean "bogging" ... sounds like you could use a tune up
any check engine lights?
Old 11-05-2008, 03:00 PM
INCNTRL4's Avatar
Default Re: car jerks (slacks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcoats1976 &raquo;</TD></TR><TR><TD CLASS="quote">sorry,thought this was a thread about people that dont like hondas...</TD></TR></TABLE>
me too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">i think you mean "bogging" ... sounds like you could use a tune up
any check engine lights?</TD></TR></TABLE>
I'd say check your fuel filter, prolly gummed up. also doesnt hurt to do a full tune up.
Old 11-05-2008, 04:10 PM
Boostn B20's Avatar
jajaja. thas funny. cause i looked at it jus now in my profile list of threads and i was thinkin, i din subscribe to any thread about car jerks.jajaja. took me a min to member.
Old 11-05-2008, 06:29 PM
jdm702's Avatar
mine does the same exact thing !!!!!!! but only 1st to 2nd it jerks hard but i can feel the lag on other gears it went away for some time but now its back !!! whats the problem ???!!!
Old 11-06-2008, 09:00 AM
civbomb's Avatar
i have the same problem, have you checked the spark plugs? i had one busted and it helped. put a new set it, turns out on of them were faulty, now its a lot better
Old 11-06-2008, 09:23 AM
Shocka1998LX's Avatar
do a full tune up, and fix any engine codes you have... check your map sensor and iacv too just for the hell of it
Old 11-06-2008, 11:35 AM
Boostn B20's Avatar
ight. can someone help me out here. thing is im a lil bit limited on cash, so i wann try to pin point wat the highest possibilty of it is first. as i was drving, i went first up to 2200 rpm, shift second, felt a lil bit of bog(falling on it's face feeling) but picked up, went up to 2000 rpm shifted 3rd, and then it jus completely fell on it's face, took about 5 seconds for it to pick up again. and if i keep goin in some severe cases, i have to stop, go back to first, and go thru the gears until it happens again. is this more likely.....fuel related, ignition related (plugs/wires), maybe dizzy?, others?
Old 11-06-2008, 11:37 AM
EJ8_Enthusiast's Avatar
you think maybe you are shifting too early?
Old 11-06-2008, 11:48 AM
Boostn B20's Avatar
yea. i kno that. but i kno how to drive too. it's a dif. feeling than wen u i guess under accelerate...it's jus like it loses every bit of power. like it stutters to get back up
Old 11-06-2008, 02:16 PM
Jonknee's Avatar
Default Re: (Boostn B20)
Are you in limp mode? do you have an eld code? any ecu codes.
Old 11-06-2008, 02:34 PM
Boostn B20's Avatar
nah, no codes, i dun think?...limp mode?
Old 11-06-2008, 03:19 PM
EJ1 LS guy's Avatar
maybe you should try taking it further...to like 4000k 1-4.....and then see if it jerks at all.....
my homie had a similar problem and it was his fuel filter....just needed cleaning.....
Old 11-06-2008, 04:36 PM
Boostn B20's Avatar
i cud do that. but first i wud have to pass 3000 rpm, and like i stated before, wen im in 3rd, at around 2000 rpm, it starts dyin out.
Old 11-07-2008, 06:14 AM
Boostn B20's Avatar
UPDATE:
i was driving/testing, and tried passing 3000rpm in second, the car wud not let me, it started dying out around 2500rpm. so i figured jus keep the pedal smashed down, hoping it wud pick up, but it doesn't, it goes down and feels like it's gonna choke/die out. but i heard something while this was happening, it let out a kinda big pop from the exhaust, like bad a/f ratio pops(i think). that said, can anybody give me a starting point as to where i shud start first. and my gauge doesn't really work, the gas or mph don't work, but i remember i have seen the check engine light come on before...it's not on now tho.
Old 11-07-2008, 07:44 AM
Boostn B20's Avatar
sorry for not posting all these updates together. car was at idle, i depressed the gas pedal the way down, got up to 5krpm, let off and hit the gas again, car stuttered and wud not pass 3krpm, so i continued depress the pedal, and the car went almost to a shut off point, as soon as i let off the gas pedal, it picks up to 2k rpm, before it goes to a normal idle.cud this be a fuel filter, or jus a fuel clog. i don't have an aftermarket intake, but i removed the bottom trap while i was doing some work earlier.
Old 11-07-2008, 08:39 AM
Boostn B20's Avatar
any one????
Old 11-07-2008, 09:58 AM
fryguy190's Avatar
Default Re: (civbomb)
first check the fuel filters... in the bay and in the tank.... check ur plugs, wires, mainly a good solid tune up...
Old 11-07-2008, 10:09 AM
Boostn B20's Avatar
y wud it back fire like it did.
Old 11-07-2008, 10:22 AM
tienzien's Avatar
your timing could be off, mine acted like that when i first installed my motor and it was timing issues. my friend hit a hard bump his timing belt jump a tooth and did the same thing.did you hit any unusal large bump lately? if you know how to do it... i would say check it out. timing adjustment would only take around an hour or so when we did it. good luck
Old 11-07-2008, 10:31 AM
Boostn B20's Avatar
i was worried bout that. wen i set the timing, i lined up the cam to it's marks, but the crank pulley, is that set on the red mark in between the two lines, or on the white mark
lll or ll
i took it to my boy's garage. and he set it, but on the way home, i heard alot of valve lashing i guess(high dings in the valvetrain at lower rpms and higher gears) and it started losing out power like what i mentioned above about 20 mins into the drive home, so wen i got home, i set the timing back to the red mark on the crank pulley, i don't get any of the valvetrain noises now, but it still loses out on the power like previously mentioned
Old 11-07-2008, 08:17 PM
tienzien's Avatar
i believe that the red mark between the 3 line is for your ignition timing. well i dont know whats the other ones called but its a single mark that stand alone. thats the right mark to set the crank to.
Old 11-07-2008, 08:25 PM
Jonknee's Avatar
Default Re: (tienzien)
Single mark is your TDC , thats how you align your camshaft in relation to your crank pulley. Ignition timing is a different story which has to do with those other marks.
Old 11-08-2008, 05:55 AM
Boostn B20's Avatar
i set the timing back to the single mark and aligned the camshaft, and the problem is still consistent. nothing really changed?
Quick Reply: car jerks
