how to determine wether starter or alternator are bad
Old 11-04-2008, 01:18 PM
elmejor's Avatar
Default how to determine wether starter or alternator are bad
i want to determine whether my starter or alternator are bad, by the way my car don't start i want to know if it could be the starter or alternator, if the starter or alternator are bad can my car get sparks, cause im not getting any sparks in my car.
Old 11-04-2008, 01:21 PM
I'm a Jackass
neardon's Avatar
If the car turns over the starter is okay. Test the voltage on the alternator to see if its good. Your coil or ignitor might be bad. You need a manual for your car to check out those ones. Google "hondahookup manuals" if you dont have one already.
sh4mr0ck's Avatar
Default Re: how to determine wether starter or alternator are bad (elmejor)
Check your battery. If your battery is dead it is most likely the alternator. Jump it, start it, and disconnect the cables, if the car dies or the battery won't hold charge for long you definitely have an alternator problem.
If the car won't even start, you have a starter problem.
(There could also be a problem with your batter, depending on how old it is.)
Old 11-04-2008, 01:25 PM
elmejor's Avatar
Default Re: how to determine wether starter or alternator are bad (sh4mr0ck)
sh4mr0ck if my alternator is bad i wont get any sparks from my dizzy?
Old 11-04-2008, 01:30 PM
I'm a Jackass
neardon's Avatar
If your alternator is bad, your battery wont be able to recharge, leaving you with a dead battery and a car that doesn't turn over.
sleepingciv's Avatar
if you have no spark its from a bad disributor not a bad alentator.The altenator has nothing to do with spark it only charges your battery to run everything
Old 11-04-2008, 01:34 PM
elmejor's Avatar
Default Re: how to determine wether starter or alternator are bad (sleepingciv)
ok so now i know my starter and alternator are good but i just replaced a used dizzy and i also tested the coil with a multimeter and its good, could it be a relay or something?
Old 11-04-2008, 01:42 PM
there are pick ups in the dizzy, did ya replace the cap and rotor in the dizzy? also did ya plug the dizzy back in after you swapped them out? i did this once lol
Old 11-04-2008, 01:47 PM
elmejor's Avatar
no i did not replace the cap and rotor and yes a plug the dizzy back, my friend is telling me it could be the ignition relay underneath the dash where the fuses are at.
Old 11-04-2008, 01:49 PM
it is possiable for that. did the car just die one day or what? why mad ya change the dizzy out for another one?
Old 11-04-2008, 01:55 PM
elmejor's Avatar
my car is giving me problems for the last month, sometimes it would start normal in the mornings and sometimes it would take like an 1 hour before i can get it on and there were time where the car would turn on for like 3 sec and then shut off, also if i idle high or redline the car would shut off, and 3 days ago i was driving the car fine, and i turn it off for like 2 hours and went i went to turn it back on it would not start, so i check if i was getting sparks and i wasn't so i changed the dizzy and still no sparks
Old 11-04-2008, 03:15 PM
Mad Scientist
mmuller's Avatar
your not overcharging right? regulator could go bad both ways.
just an idea
check ignitor wires to be tight on their spade
Old 11-04-2008, 03:19 PM
Default Re: how to determine wether starter or alternator are bad (mmuller)
Have you tried a different ecu?
Is the ecu putting any codes out?
Old 11-05-2008, 05:21 AM
elmejor's Avatar
i have not tried a different ecu but i will, and its not throwing any codes
Old 11-05-2008, 05:34 AM
I'm a Jackass
neardon's Avatar
Your ECU has nothing to do with the spark. Neither does the relay under the dash. Have you checked the ignitor?
Old 11-05-2008, 05:44 AM
elmejor's Avatar
Default Re: how to determine wether starter or alternator are bad (neardon)
i check the ignitor everything is plug in but have not tested it cause i dont know how to do it, by the way my coil test was the primary test was 0.3 ohms and secondary coil test was 12.22K is it good cause shown in this article http://www.team-integra.net/se...=1114 it suppose to be 0.6-0.8 for primary and 12.9k-19.2 for secondary
Old 11-05-2008, 07:54 AM
elmejor's Avatar
so with this readings is my coil good or not
Old 11-05-2008, 08:00 AM
I'm a Jackass
neardon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmejor &raquo;</TD></TR><TR><TD CLASS="quote">so with this readings is my coil good or not</TD></TR></TABLE>
The numbers are obviously out of spec. Your coil is bad.
Old 11-06-2008, 04:15 AM
drussell4801's Avatar
yeah, the numbers are out of spec, but i bet if you checked any old *** used dizzy from one of our cars, it'll be out of spec a bit.
You should replace it if its out of spec, which it is, but don't expect that alone to get the car running.
Old 11-06-2008, 07:12 AM
elmejor's Avatar
Default Re: (drussell4801)
i just hope its not a wire harness problem
trvis
03-26-2005 11:02 AM
LSEGHATCH
20
02-05-2005 07:06 PM
95greenteg
11-29-2004 02:56 PM
riceanator01
05-08-2002 01:07 PM
Quick Reply: how to determine wether starter or alternator are bad
