2006 Honda Civic SI Torque Specs
Hello,
2006 Honda Civic SI Coupe
Could somebody with the service manual look up a couple of specs for me please. Or if somebody knows where to download and or reference the manual online a link would work too.
I need the torque specs for the FLCA to the subframe, both bushings. Brake caliper to knuckle. Lower ball joint to knuckle. Tierod to knuckle. Knuckle to strut. Wheel lug nuts.
All of this is for the front.
Thanks in advance!
Thanks in advance!
Re: 2006 Honda Civic SI Torque Specs (Dimazz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimazz »</TD></TR><TR><TD CLASS="quote">
Re: (SIVIC 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 »</TD></TR><TR><TD CLASS="quote">^for the k20z3, i assume. thats what you asked about.
i put down 143 ft/lbs. but im i/h/e etc.. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimazz »</TD></TR><TR><TD CLASS="quote">Hello,
Thanks in advance!</TD></TR></TABLE>
NO MERCY!
Wheel lug nut specs are 80ft./lbs for all wheels. Not sure about the rest of the specs though.
My advice.....drive to a HOnda dealership and around back to the actual service shop entrance and see if you can speak to a technician directly. If they're cool enough they'll look it up for you on the spot.
Front side of the lower arm mounting bolt-61
Rear side of the lower arm mounting bolt-47
The flange bolt and the self-locking nuts from the lower arm-43
Caliper to knuckle-80
Info taken from Honda interactive network. Same source technicians use. Hope this helps.
