Key won't turn...
Old 10-03-2008, 05:03 PM
g2tegsown's Avatar
Default Key won't turn...
Alright so I go to start my car today and the damn key won't turn... after messing with it for a bit it turns and the car starts. I get to work and try and turn the car off, and the key it stuck in the on position. So after F**king with it for awhile I get it to turn off. Now everytime it's the same situation...
It's acting kinda like the steering wheel is locked but it's not... And it's bending my key trying to turn it off, I have to actually leave it on the 1st dot instead of turning it all the way off.
Any ideas?
Old 10-03-2008, 05:10 PM
zrickety's Avatar
Default Re: Key won't turn... (g2tegsown)
ignition lock is probably on it's way out...get a new one from honda
Old 10-03-2008, 05:11 PM
Ak_ef9's Avatar
Sound like your using the wrong key. I have done that with my car a few times. Having 3 honda keys that look the same on the same key ring sucks
Old 10-03-2008, 05:46 PM
g2tegsown's Avatar
Default Re: Key won't turn... (Ak_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">Sound like your using the wrong key. I have done that with my car a few times. Having 3 honda keys that look the same on the same key ring sucks</TD></TR></TABLE>
Only car key on the ring is my rex... it's never been the wrong key...
I'm sure zrickety is probably right. Won't I need a whole new key and lock assembly?
Old 10-03-2008, 09:34 PM
guysensei's Avatar
It could be either or it could be your key is worn and lost its shape so its getting stuck or it could be that your switch is on its way out.If you can find a switch with a key swap it. If not take the switch out and take it to a locksmith it could just need a little grease and a new key. Good luck on this one.
Old 10-03-2008, 11:32 PM
Pee Wee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2tegsown &raquo;</TD></TR><TR><TD CLASS="quote">
I'm sure zrickety is probably right. Won't I need a whole new key and lock assembly?</TD></TR></TABLE>
you can get them from autozone for cheap, and they come with keys
Old 10-04-2008, 01:53 PM
tico's Avatar
get a new one from Honda.(highly reccomended) take it to a legit locksmith and have them match ur existing key to the new lock.
ckj
Honda CR-V & Element
11-18-2017 02:58 PM
dreaducky
Honda Civic (2006 - 2015)
08-10-2013 07:08 AM
professorman
08-08-2011 03:42 PM
keymclean
10-28-2007 07:17 AM
fkguitar
08-06-2005 10:03 AM
Quick Reply: Key won't turn...
