Please Help ASAP... My clutch wont fully engage...
As the topic states I am having a problem with my clutch. I have a 98 4dr GSR with a B18C motor and a B16 tranny. The clutch doesn't want to engage all the way so I cant put the car into gear and if I start the car in gear it shakes like it is trying to move forward and makes a scrapping sound and I cant take it out of gear. I tried bleeding the clutch line and that didn't help at all. Please help me figure this out. Thank you.
Re: Please Help ASAP... My clutch wont fully engage... (ender214)
Could the clutch be completely toast? If you replaced it... Did you install the pressure plate the correct way?
Re: (ender214)
check for any fluid leaks from the CMC and the lines. If you source a leak, fix it. If you do bleed the lines, it takes awhile to get it right so you have a good pedal feel. This is important as you may likely have air in the lines, thus causing the problem. I had this issue, couldn't get it in gear, started in first and it would shudder forward as i started the car.
Re: (b20beast83)
Im having a similar problem, but nothing is happening when the clutch pedal is pressed in. It just keeps going.
The car runs and will move but you i cant push the clutch in and stop, it just keeps on moving
ok for any one that is following this I got in the car and I was going to limp it over to my parents house to go ahead and drop the tranny and the problem just stopped. it is driving like a champ right now. I dont know what to make of it...
Re: (ender214)
that sounds like a broken spring on the clutch disc...did you hear **** rattling around? ...I would still pull it apart even if it is running right now, cause **** like that doesnt just happen and then go away...and when it acts up again it is going to be at the worst possible moment...it only takes 2 hours to pull it and verify that nothing is fukt
Re: (srmofo)
I didn't hear anything rattling in there but I am going to end up pulling the tranny to make sure everything is ok inside as soon as I find time, with the way my schedule is going that wont be till like november . Thanks everyone for your input.
hndacord02
02-27-2007 07:17 PM
StrangerWitCandy
06-10-2004 04:28 AM
