cruise control wont work
I have a 92 accord ex AT and When i turn on the cruise control the cruise control light on the dash turns on and when i take my foot off the gas the car doesnt stay at that speed it just drops and drops. if i press the accelerate button it wont accel unless im at 45-55mph. checked for vacuum leaks but couldnt find any. any ideas?? Thanks in advance.
Re: cruise control wont work (boarding2008)
Check for loose or broken cable in throttle body. Maybe a bad diaphram on CC unit itself. Check fuses and Relays if is not a vacumm controoled unit.
Re: cruise control wont work (99accordFX)
I havent had a chance to check any of those. I went to Cedar Point OH, about 225 miles, and when i got up to 60+ mph it stayed where it should and the accel and decelerate buttons works. Just Puzzles me. My guest is the cc unit or the diaphram
Re: (TheMuffinMan)
from what I remember, Cruise control works after 30mph. If your cruise control doesn't work at all then U have a problem with impedence, there are two lights in the push button that goes green when U push, when U set the button on the steering, it turns on at U'r dash light.
