whats the best way to restore Faded Red Paint on a car
* B A N N E D *
whats the best way to restore Faded Red Paint on a car WITHOUT a new paint Job ...i have money for other parts motor, rims and all that but no money for NEW paint how do i restore the original shine or atleast make it darker red or Anything that make it shine again ..
* B A N N E D *
Re: whats the best way to restore Faded Red Paint on a car (DAP91Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAP91Si »</TD></TR><TR><TD CLASS="quote">You could try a polishing compound.</TD></TR></TABLE>
what do i need to polish it ??
Re: whats the best way to restore Faded Red Paint on a car (mackadocious)
A machine would help but you can try it by hand. Turtle Wax sells an inexpensive polishing compound that you can try.
* B A N N E D *
Re: (markk449)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markk449 »</TD></TR><TR><TD CLASS="quote">nothing once the base coat is faded the only way to fix it is to repaint it</TD></TR></TABLE>
im go look around for that kind of wax..its called repaint wax right ? LOL
Re: (mackadocious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mackadocious »</TD></TR><TR><TD CLASS="quote">
im go look around for that kind of wax..its called repaint wax right ? LOL</TD></TR></TABLE>
sorry, this post was an epic fail.
* B A N N E D *
Re: (rf0bbish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rf0bbish »</TD></TR><TR><TD CLASS="quote">
sorry, this post was an epic fail.</TD></TR></TABLE>
Shut up u suck
Shut up u suck
Re: (mackadocious)
to restore oxidized paint, you will need a compound and at the very least a dual action polisher. dont listen to these clowns saying "clay and wax" or to use turtle wax rubbing compound.
i didnt try on red car but, for my accord i used to own was black, and i went cheap route, i used turtle 3 dollar polish paste in a smal plastic can thing, its white with green lable, then i brough a 7inch walmart 20 dollar buffer, and spend some time buffing it, came out pretty good, dont use the PRO 1800 rpm one if u never try buff before, u can burn through ur paint... so that little 25 bucks can save u some money and make it look better, then use the yellow bottle scratch and swilr remover, its like 3 bucks or 5 bucks for big bottle, then use wax of ur choice, i recomment wax by hand, idk just me lol
Re: (Civic_4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_4life »</TD></TR><TR><TD CLASS="quote">i didnt try on red car but, for my accord i used to own was black, and i went cheap route, i used turtle 3 dollar polish paste in a smal plastic can thing, its white with green lable, then i brough a 7inch walmart 20 dollar buffer, and spend some time buffing it, came out pretty good, dont use the PRO 1800 rpm one if u never try buff before, u can burn through ur paint... so that little 25 bucks can save u some money and make it look better, then use the yellow bottle scratch and swilr remover, its like 3 bucks or 5 bucks for big bottle, then use wax of ur choice, i recomment wax by hand, idk just me lol</TD></TR></TABLE>
Epic fail post.
I know you said no deals on repaint. But without seeing your car I'm going to assume by "faded" you mean "[freak]ed". Can't fix something once the paint has turned pinkish/white.
Epic fail post.
Re: (cpgottabuh)
Wow this post is full of many MISinformed people. Wax will do NOTHING for his particular situation other than make it shiny. You're going to need to purchase a buffer and hit it with a color restoring compound.
What we really need is pictures, good pictures. You're probably **** out of luck with a faded red car, but only pictures will answer that for sure.
* B A N N E D *
Re: (GuNnErGoD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GuNnErGoD »</TD></TR><TR><TD CLASS="quote">That Paint looks done for. Buffing it will still bring back a few panels it looks like. Give it a try, you might learn a few things in the process</TD></TR></TABLE>
so which one shud i use ..Polishing compound or Rubbing compound ??
Genetically Gay
Re: (mackadocious)
nah..man don't waste your money on wax compound you're gonna spend almost about $50 paint job.i would suggest you start prepin it away and lay that new paint job over the car.
Re: (KILLAB17VTEC)
/\ he's asking for factual advice, not .
even $50, $60, or $150 in compound and buffing materials, it's still cheaper than a new paint job if he can't afford it or doesn't want to pay for it now.
Re: (KILLAB17VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KILLAB17VTEC »</TD></TR><TR><TD CLASS="quote">nah..man don't waste your money on wax compound you're gonna spend almost about $50 paint job.i would suggest you start prepin it away and lay that new paint job over the car.</TD></TR></TABLE>
whats wax compound?
whats wax compound?
Your just going to wast your time if you buff it. Once the base is faded your screwed. But if you want, use a light buffing compound and a wool pad and then a swirl mark remover compound and a black egg create foam pad
Re: (mackadocious)
I had an EG hatch that had similar paint issues and I used polishing compound on it with a buffer and then went over it with a good wax(liquid glass) and it looked almost new except at night under street lamps. I would go that route...
Re: (EG_Warped)
Using a buffer with a good compound or a decent rubbing compound is just a pacifier for a paint job. Some of those panels will look a lot better, some are toast. Take it from me, if you're looking for a paint job alternative, you won't find one in any compound with your paint job being in the shape that its in. It may look better for a few weeks, but a paint job is the only true permanent solution to your problem.
