programming a key fob
Old 05-24-2008, 02:12 PM
matthevelli's Avatar
Default programming a key fob
i have a 2001 honda accord and i was wondering if anyone could tell me how to program the key fob i just got for it
Old 05-25-2008, 10:02 AM
hondadude's Avatar
Default Re: programming a key fob (matthevelli)
I dug up a S/B from 98
Says to turn on the ignition; then within 5 seconds press the lock button on the key fob, within 5 seconds shut off the ignition.
Repeat this 3 times
Old 05-27-2008, 02:43 PM
Default Re: programming a key fob (hondadude)
i tried turning it on and off but it did not work does it matter that i got the key fob out of another accord and it was already programmed.
Old 05-27-2008, 05:26 PM
hondadude's Avatar
Does the little light on the key fob turn on when you press the lock/unlock button?.
What year/trim Accord did the key fob come from?
What trim level is your Accord?
Can you read the Part number on the back of the key fob?
I'll go log on to ISIS if I have correct info to deal with
Old 05-29-2008, 05:14 PM
yes the light comes on when i hit the buttons but i dont know the exact year or trim it came from i know it was between 98 and 02 not sure if that helps its going to a 01 accord LX and the code on the back of the key fob is KOBUTAH2T
Old 05-29-2008, 06:26 PM
hondadude's Avatar
Okay I got ya a couple screen shots;
this might help you ID the transmitter
and here is the programming steps;
Old 05-31-2008, 05:44 AM
thanks ill give it a shot
Old 03-25-2014, 10:29 AM
joeblogs's Avatar
pls can any one help 2001 sport key fob not working thanks
Old 03-25-2014, 11:10 AM
joeblogs's Avatar
plus does anyone no the reciver postion on the car thanks
Old 03-25-2014, 04:39 PM
dseriesboulder's Avatar
can you add a fob to a car that originally has power locks?
El Nato
09-05-2017 12:38 PM
pnutt88
02-28-2012 10:07 PM
dazco
01-11-2007 08:39 AM
itchy
04-30-2002 11:44 AM
Quick Reply: programming a key fob
