ap1 wheels
Old 05-15-2008, 10:55 PM
weak_sauce's Avatar
Default ap1 wheels
Will the Honda s2000 ap1 wheels fit on the 05 rsx with no rubbing issue? I know for sure 4 front ap1 wheels will fit but not sure of the rear. Please help me out. Thanks
Old 05-16-2008, 09:07 AM
SkankyEJ7's Avatar
Default Re: ap1 wheels (weak_sauce)
No, I'm pretty sure only the fronts fits.
Old 05-16-2008, 02:36 PM
weak_sauce's Avatar
So the rears will rub tremendously?
Old 05-16-2008, 02:39 PM
SkankyEJ7's Avatar
Default Re: (weak_sauce)
I'm not sure if its to do with the hub's of the offset, I just know that I have read that only the fronts fits.
Old 05-16-2008, 06:18 PM
weak_sauce's Avatar
Thanks! Any other recommendations ?
Old 05-16-2008, 06:28 PM
young noob #2's Avatar
just a thought, but I know that on ep3's that fitting 225's requires rolling the rears but not the fronts, so maybe you could switch the ap1 wheels and use the rears on the front and vice versa, even run a staggered a set-up to allow our rear to rotate more, thats what im doing, just not with ap1 wheels, just getting rota's or sportmax and running 225's up front and 215's in the back, what exactly is the offset and rim width on the ap1 wheels?
Old 05-18-2008, 01:37 PM
RudyCholo's Avatar
I've always wanted to see ap1's on a dc5. Are they 16's?
Old 05-18-2008, 01:40 PM
DC5_lov3r's Avatar
Default Re: (RudyCholo)
I think you need to run spacers to make them stick out more.
Old 05-18-2008, 09:25 PM
lend_type_R's Avatar
Default Re: (young noob #2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob #2 &raquo;</TD></TR><TR><TD CLASS="quote">what exactly is the offset and rim width on the ap1 wheels?</TD></TR></TABLE>
AP1 OEM US wheel spec same as JDM BBS 6 spoke rim (lighter)
16X6.5 +55 front
16X7.5 +65 rear
Old 05-19-2008, 12:41 PM
Default Re: (lend_type_R)
jesus thats one hell of an offset, I didn't know they were that positive, you could always get extended studs and run spacers......there is a member on ephatch.com that is using this set-up and it looks awesome, ill go get it here shortly
Old 05-19-2008, 12:43 PM
http://www.ephatch.com/forum/s...age=4
Old 05-19-2008, 06:48 PM
how about AP2? heres the spec
17" x 7.0", +55 offset
17" x 8.5", +65 offset
Old 05-19-2008, 07:27 PM
J_Bones's Avatar
im running 06 type s brake setup with no spacers. zero problems what so ever. they do stick in a little bit, but nothing to slot car-ish.
Old 05-20-2008, 02:57 PM
GradyDC5's Avatar
25mm Spacers will put you flush. 25mm spacers flush out my itr's on my type-s.
Old 05-24-2008, 09:39 PM
weak_sauce's Avatar
sweet..im put them on and see how it goes.
Old 05-25-2008, 02:08 AM
thetunersource's Avatar
man that **** looks gooood
Old 05-25-2008, 04:28 PM
DC5RHD's Avatar
Default Re: (thetunersource)
Now you guys running ap1 wheels, are you just using 2 sets of fronts? because ive heard that u cant use the rears..
Old 05-25-2008, 05:27 PM
J_Bones's Avatar
Default Re: (DC5RHD)
got it. 4 fronts all around.
Old 05-26-2008, 03:15 AM
thrty8street's Avatar
Default Re: (J_Bones)
how heavy are the the AP1 wheels?
Old 05-26-2008, 03:41 AM
HondaKyle's Avatar
I vote on the stock rims look better on the car.... With the money and time you spent looking for a set of the AP1 wheels you could have some rotas...
Old 05-26-2008, 06:06 AM
phylast's Avatar
Default Re: ap1 wheels (HondaKyle)
wow, those look good
Old 05-26-2008, 06:50 AM
Default Re: (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">how heavy are the the AP1 wheels?</TD></TR></TABLE>
their heavy, might as well go with rotas for performance. but if you really want the s2k wheel looks then heres for you.
AP1 USDM cast 16's
front 17.5 lbs
rear 18.6 lbs
AP1 JDM BBS forge 16's
front 13.3 lbs
rear 14.3 lbs
AP2 USDM cast 17's
front 17.6 lbs
rear 20.5 lbs
Old 05-26-2008, 12:23 PM
what do the jdm bbs look like?
Old 05-27-2008, 09:19 AM
J_Bones's Avatar
Yeah i opted for the stock look. Not into performance, just yet. K20a3 =
Old 05-27-2008, 06:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">what do the jdm bbs look like?</TD></TR></TABLE>
here they are.
Quick Reply: ap1 wheels
