88-89 Crx HF cluster wire diagram
Old 04-25-2008, 10:10 PM
KhmerdudeSiR's Avatar
Default 88-89 Crx HF cluster wire diagram
I been looking around h-t for a 88-89 crx hf gauge cluster diagram because I'm planning on switching the plugs over to 90-91 so i can use the 90-91 gauge cluster, i was told all wires go up except for a couple and i just want to make sure before i go slicing away, i been searching for this info but the only thing i can find is a bunch of "how to" about 90-91 wire diagram and nothing with the 88-89 models, if someone can help me with this is will be much appreciated, thanks in advanced
Old 04-26-2008, 10:00 AM
Default Re: 88-89 Crx HF cluster wire diagram (KhmerdudeSiR)
ttt
Old 04-27-2008, 06:13 PM
Come on, i know someones done this before, so help a fellow Ef owner out =]
Old 04-27-2008, 06:21 PM
superex87's Avatar
Default Re: (KhmerdudeSiR)
search through all of the faq.......someone has to have done it befor, also DO NOT SLICE, just repin the plugs sooo much eaiser and neater
Old 04-27-2008, 06:31 PM
DCFerris's Avatar
http://www.angelfire.com/ca/DrOhm/SiRcluster.html
This is for a 91 crx si into a euro cluster but you can look at the wiring for the 91
Old 04-27-2008, 10:30 PM
Default Re: (superex87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superex87 &raquo;</TD></TR><TR><TD CLASS="quote">search through all of the faq.......someone has to have done it befor, also DO NOT SLICE, just repin the plugs sooo much eaiser and neater</TD></TR></TABLE>
I done that all day, i even tried to put together my own little FAQ for future reference to anyone trying to do the same,
Old 04-27-2008, 10:33 PM
Default Re: (DCFerris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCFerris &raquo;</TD></TR><TR><TD CLASS="quote">http://www.angelfire.com/ca/DrOhm/SiRcluster.html
This is for a 91 crx si into a euro cluster but you can look at the wiring for the 91</TD></TR></TABLE>
thanks now all i need is the 88-89 wire diagram but all i can find are the ukdm ones with all those extra things i don't need and was told it was off by a few plugs, haha but if anyone can supply me with a 88-89 wire diagram lmk, when I'm done Ill make a write up for future reference to other 88-89 owners
edit: After reading over it fully this is what i was actually looking for, they talk about the us 88-89 plugs also, ill go do the cluster swap and post pics and a small write up for anyone else attempting to do the same, thanks DCFerris
Modified by KhmerdudeSiR at 11:42 PM 4/27/2008
Old 04-27-2008, 11:22 PM
DCFerris's Avatar
These pics say 88-89 us crx and civic i hope this helps
Modified by DCFerris at 12:29 AM 4/28/2008
Old 04-28-2008, 05:26 PM
well today i attempted to do the cluster swap with the info provided and other info from various H-T threads, and my plugs are way off from the chart provided above, i tried color to color and that didnt work out, i even tried to do what i thought might work but that failed also , i think maybe HF wiring maybe diff from other dx/si 88-89 models, idk but here are pics of my 88 HF plugs i clipped off my harness lmk if any of this looks familiar...
Old 04-28-2008, 05:46 PM
Here are my 91 dx plugs, i looked around threads and found that my 91 plug is off some wires, idk lmk
Old 04-28-2008, 06:02 PM
jdm498's Avatar
90-91 hf crx
8-pin harness
1.blk=ground
2.yellow-red=not used
3.empty
4.green- black=trunk light
5.blu-red=seat belt
6.yellow- white=fuel guage
7.yellow= power
8.green-yellow= right turn signal
12 pin harness
1.green- blue=left turn
2.red blue=high beem
3.yellow-green= cool temp
4.red black=brightness control
5.red=guage light
6.blk- yellow=not used
7.green -red= e brake
8.yellow -red= oil light
9.geen orange=check engine light
10.black -yellow=power cluster
11.white-blue= battery
12.blue=tach
I have installed a 88 cluster in my 91 and you will need some extra wire to extend the wires when converting.so it is vice versa.
Modified by jdm498 at 3:30 AM 4/29/2008
Old 04-28-2008, 06:19 PM
jdm498's Avatar
Default Re: (jdm498)
88-89 crx
8-pin harness
1.blk=groun
2.red- blue= high beam
3.green -black= tac light
4.green- red= e brake
5.yellow -red= not used
6.empty
7.yellow = power cluster
8.green - yellow=right turn signal
12- pin.
1.green -blue=left turn
2.blue -red=seat belt light
3.yelllow -green= coolent temp
4.yellow white= fuel guage
5.yelow-red=oil light
6.red= guage light
7.red -black=bright control
8.black-yellow= power cluster
9.white -blue=battery
10.green -orange=check engine light
11.blue=tach
12.blue -yellow=not used.
there u go hope this helps .I have it drawn out as well so I think im ganna post up a diy 'er diagram tomorrow.you have to match these to color.yes it was a beeeatch!
Old 04-16-2012, 08:39 PM
Shanemwells's Avatar
You know i am doing exactly what you are doing but in reverse i am putting a 91 crx cluster in my 88 crx and i am having a slight wiring issue. It seem the 91 has a extra wire in the plug with 12 wires then the 88 hf 12 pin cluster. My temp and fuel gauge and high beam indacator seem to be not working. Also the 90-91 cluster has the seat belt indactor light also. I tried to follow your diagram but in reverse and thats the problem i got from it lol. Any help would be appreciated thanks.
GroundZer0 336
04-18-2012 10:24 PM
pnk_03
01-09-2008 07:54 AM
AndrePerras
12-03-2006 06:16 PM
rewerbcrx
09-16-2005 07:07 PM
2kTeg
05-25-2005 11:24 AM
Quick Reply: 88-89 Crx HF cluster wire diagram
