95 civic will not shift into gear PLEASE HELP!!!!!!
Old 02-25-2008, 05:25 PM
almostjdmeg's Avatar
Default 95 civic will not shift into gear PLEASE HELP!!!!!!
I have a 1995 civic that will barely shift into gear. It was doing fine until today, i go to pull out of the parking lot and the thing will not shift into gear for anything. The clutch feels like there is nothing there but when i finally do get it into gear and get going it is fine. I dont understand what is causing this problem. Please does anyone have any ideas?
Old 02-25-2008, 05:33 PM
BigBoostinJK's Avatar
Default Re: 95 civic will not shift into gear PLEASE HELP!!!!!! (almostjdmeg)
It could be clutch, or fluid, or something is wrong with tranny, could be shift linkage...it could be a number of things.
Old 02-25-2008, 05:40 PM
Default Re: 95 civic will not shift into gear PLEASE HELP!!!!!! (BigBoostinCJ)
I put new fluid in and the tranny should be good, but i did just install an ebay shifter, could that be the problem and if so what would be the problem?
Old 02-25-2008, 05:52 PM
Blzdeep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almostjdmeg &raquo;</TD></TR><TR><TD CLASS="quote">I put new fluid in and the tranny should be good, but i did just install an ebay shifter, could that be the problem and if so what would be the problem?</TD></TR></TABLE>
Did you put the right weight in ? I did that once in a nother vehicle, put in the wrong weight and the damn thing wouldnt shift for doodoo, unless i could acually get it going in first.
Old 02-25-2008, 05:58 PM
Default Re: 95 civic will not shift into gear PLEASE HELP!!!!!! (Blzdeep)
What do you mean the right weight, and im just wondering how that would affect the shifting.
Old 02-25-2008, 06:00 PM
Blzdeep's Avatar
i think your fine im thinking trucks and gear oil long day, you said you put a new shifter in it . i am not the one to say what may be wrong with it, but if your trouble started after you installed it, i'd start there bro. Someone will be on here to clarify it for you, Alot of really knowledgable peeps here, give a couple minutes.
Old 02-25-2008, 09:07 PM
lilo_goki's Avatar
if u install a new shifter, did u tighten the nut/bolt reallie hard, if u did then that's the problem. you have let it loose until u can acutally shift perfectly. sometimes that's the problem.
Old 02-25-2008, 09:14 PM
* B A N N E D *
99GreenEX's Avatar
The bolt being too tight would be that bad an issue since the bolt runs through a sleeve.. What it may be is that he did not use the correct spacer set. Check the instructions of it came with any, and also search for shifter install DIY's. Look at the pics there (or read) and detirmine if you used the right amount of spacers..
Old 02-26-2008, 01:10 PM
lilo_goki's Avatar
acutally if it's too tight then u won't even be able to shift.
Zakaria Ism
Transmission & Drivetrain
04-26-2016 07:51 AM
Mmmeecho
10
07-28-2008 09:06 PM
boosted_EM1
12
02-07-2008 12:58 PM
AzntstyleZ
06-27-2005 08:21 AM
iMaGin
04-22-2004 12:53 PM
Quick Reply: 95 civic will not shift into gear PLEASE HELP!!!!!!
