o2 sensor wires on 92 civic dx
Old 01-22-2008, 05:13 PM
hondamonda's Avatar
Default o2 sensor wires on 92 civic dx
here is the problem. i did a ls 98 ls swap on my 92 civic dx. i'm using a dx engine harness and the car is running fine. the one problem is that i do not see where i have to connect the o2 sensor. i only see a couple of extra plugs and i dont believe they are the ones. any one have a description or the wire colors for the o2 sensor wires coming off the harness?
Old 01-22-2008, 05:22 PM
z6hatchboy's Avatar
Default Re: o2 sensor wires on 92 civic dx (hondamonda)
The o2 sensor on the dx harness is paired with the vss, ect, and whatever the other one beside that is at the front of the motor. As for the color i cant say.
Old 01-22-2008, 07:28 PM
hondamonda's Avatar
Default Re: o2 sensor wires on 92 civic dx (z6hatchboy)
bump....any one know the wire colors on the harness for the o2 sensor?
Old 01-22-2008, 09:13 PM
wangkata's Avatar
should be 4 wires WHT/YEL,BLK/GRN,WHT/ORN,BLK......
Old 01-23-2008, 06:53 AM
hondamonda's Avatar
Default Re: o2 sensor wires on 92 civic dx (wangkata)
ok i see a white, yellow/ black, orange black, and a green white wires not plugged into any thing and its near the front of the motor . and the o2 sensor is down under on the headers, the wires on the 02 sensor are green, whire and there are 2 black wires. can any one match them up for me?
Old 01-24-2008, 05:18 PM
hondamonda's Avatar
ok i got it hooked up. at first i was going to cut the wires and make them longer but then i just figured to open up the harness and pull the harness for the o2 sensor out until it is long enough . its good now but it is still showing the code for the o2 sensor and i think i need the tps also because of teh rough idle. another issue, this never ends.
808DA
06-01-2011 09:08 AM
accord2civic2prelude
10-11-2010 07:29 PM
-=ZAK=-
05-03-2009 04:43 PM
akteamster
12-01-2005 12:28 AM
StudioJDM
02-16-2003 12:06 AM
Quick Reply: o2 sensor wires on 92 civic dx
