trouble mounting my ASR rear 24mm sway bar on my 2000 civic si
Old 12-28-2007, 07:51 AM
Tuner Eddy's Avatar
Default trouble mounting my ASR rear 24mm sway bar on my 2000 civic si
Alright fella's, I ordered my ASR 24mm sway bar from weaksauce a few weeks back and decided to put it on tonight. I noticed while trying to line the holes up with the "D" brackets that the holes for the bolts were covered by the bracket when one bolt would go in.
To try and make better sense of it, only one bolt on each side of the D bracket would line up, and the other hole would be covered by the bracket.
This frustrates me, because i remember asking Weaksauce on the phone if the ASR sway bar would work with my Carbing rear lower tie bar, and they were firm with their assurance that it would work.
So I am asking, do I need to have the ASR subframe brace in order to run the sway bar?
Old 12-28-2007, 07:58 AM
feeldabazzgsr's Avatar
Default Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (Tuner Eddy)
I am pretty sure you might need ASR brace...are you sure you wanna install that gigantic bar without brace?...i think it would tear apart your subframe if you install it without brace
Old 12-28-2007, 11:35 AM
Tuner Eddy's Avatar
you have to have the subframe brace to run the bar. bout to order it.
Old 12-28-2007, 11:45 AM
BlueIntegraBoy's Avatar
Definitely need one. If you were to somehow mount it, subframe tearout would occur the first time you try to test out the sway bar.
Old 12-28-2007, 12:42 PM
C-West Civic's Avatar
Pics??? I just did the ASR brace with a Cusco 24mm rear sway and it went on fine.
Old 12-28-2007, 12:52 PM
Tuner Eddy's Avatar
Default Re: (C-West Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-West Civic &raquo;</TD></TR><TR><TD CLASS="quote">Pics??? I just did the ASR brace with a Cusco 24mm rear sway and it went on fine.</TD></TR></TABLE>
you got pics of your setup? i dont have any.
Old 12-28-2007, 02:40 PM
Default Re: (Tuner Eddy)
Lemme know where your having your problem at based off my photo.
Old 12-28-2007, 02:43 PM
KBG Indey's Avatar
I think the problem he's having is that he has a cusco TIE BAR
and ASR SWAY BAR
Not the other way around, like you have =P
Old 12-28-2007, 02:48 PM
Na cuz he is sayin that his D bracket is covering th other hole that it should mount up to.
Do you have the right size D brackets? You need the bushings and brackets from the ITR
Old 12-28-2007, 04:59 PM
KBG Indey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-West Civic &raquo;</TD></TR><TR><TD CLASS="quote">Na cuz he is sayin that his D bracket is covering th other hole that it should mount up to.
Do you have the right size D brackets? You need the bushings and brackets from the ITR</TD></TR></TABLE>
Sorry about that was thinking about endlinks, not d brackets.
JiNxXx0013
Suspension & Brakes
09-16-2017 07:26 PM
uvamosk
Suspension & Brakes
11-13-2011 07:35 AM
exist12
11-29-2009 10:52 PM
mugen si
05-03-2009 06:29 PM
Tuner Eddy
Suspension & Brakes
12
12-28-2007 01:35 PM
Quick Reply: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si
