Jack Point for raising the Fit?
Changing the oil for the first time in my new Fit. I don't see any lift point (i.e. front crossmember) for my floor jack. Rear tow hook is present though
Where have you guys lifted up the front with a floor jack?...or am I just limited to lifting behind each front wheel (PITA).
I like to raise all four wheels off the ground and rotate tires when changing oil.
Thanks
Thanks
Re: Jack Point for raising the Fit? (n1_egsex)
Thanks! I thought that was the case, but didnt remove any of the plastic splashguards under the bumper/radiator to take a super close inspection.
Re: Jack Point for raising the Fit? (kwichang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex »</TD></TR><TR><TD CLASS="quote">i jack it up from the side</TD></TR></TABLE>
me too..
but i have seen this before.. http://www.hondafitjazz.com/ma....HTML
me too..
Re: Jack Point for raising the Fit? (07ssmfit916)
Very cool 07ssmfit96! - bonus points for the Helm's manual diagram
Guess I should have taken off the splashguards and taken a closer look!
I've used the rear tow hook to jack mine up before (not for an oil change obviously) and it worked well.
Maybe it's just my jack, but I can't comfortable get to that front point on the lower rad. support.
When doing an oil change I always raise the vehicle on the driver's side. Be sure to use jack stands while you are under the car.
Swaggylicious
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07ssmfit916 »</TD></TR><TR><TD CLASS="quote">
me too..
actually on the usdms theres that bowl behind the tow hook and that's the jacking point for the back,for the front?who knows..lol...i cant even slide a jack that far under anymore
me too..
Re: Jack Point for raising the Fit? ($amGD3)
ramps.. atleast, that's what i use for my current cars. i haven't changed the oil in the fit yet. only 900 miles so far.
Re: Jack Point for raising the Fit? (E-AT_me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-AT_me »</TD></TR><TR><TD CLASS="quote">ramps.. atleast, that's what i use for my current cars. i haven't changed the oil in the fit yet. only 900 miles so far. </TD></TR></TABLE>
My Sport wouldnt clear my ramps
Swaggylicious
Re: Jack Point for raising the Fit? (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL »</TD></TR><TR><TD CLASS="quote">
My Sport wouldnt clear my ramps </TD></TR></TABLE>srsly,i never owned a car that could go on those ramps my dad got me
i've got the small plastic rhino ramps, and even my lowered 86 fits on them. but i don't know about the fit. the front over-hang is a lot. if i set it up right, it should be able to go on them. (slightly sloped driveway. i can play with approach angles)
Re: Jack Point for raising the Fit? (teh cure)
Takata LDS wheel ramps for lowered cars. The wheel ramps are made by out dated and recycled Takata harnesses, no joke! I need to buy me a set of these before they are all gone...
http://www.jhpusa.com/catalog/...d=733
