good place to hide a kill switch...
Old 10-18-2007, 09:22 PM
MIXINinthe805's Avatar
Default good place to hide a kill switch...
what do you guys think?
Old 10-18-2007, 09:32 PM
denraweb's Avatar
Default Re: good place to hide a kill switch... (MIXINinthe805)
Rather not say? lol
Use your imagination...
Old 10-18-2007, 10:12 PM
gourley's Avatar
Right on the steering wheel, make sure you put a sticker under it that says " Kill Switch" so you and others dont forget
j/p, put it somewhere you think no one will notice and thieves wont think it will be there.
AKA under a seat or behind your Cd player. Its your call
Old 10-18-2007, 11:09 PM
Foxcow's Avatar
Default Re: good place to hide a kill switch... (gourley)
what would you put the kill switch on? Power for the fuel pump or battery power? Ignition? I really don't know.
Old 10-18-2007, 11:21 PM
ef dino's Avatar
Default Re: good place to hide a kill switch... (Foxcow)
Its all up to you man. No ones gonna give out there hiding spots. Be creative, make a fuel cut switch somewhere and an ignition cut somewhere else. And if you wanna go all out make switches for every damn thing in the car. You can make a switch to control your mothers ******* just be creative with where your putting these switches. Your car, your switches. Hide em good!
My buddys got a setup where you have to hold the cigarette lighter down then push the ac button.. You can do WHATEVER you want. If you have an idea and want directions on how to wire it pm me ill give you a very detailed way of how to wire anything you want. hope that helps a bit
Old 10-18-2007, 11:47 PM
JKGONZALEZ3's Avatar
Default Re: good place to hide a kill switch... (ef dino)
ill tell you mine cause you never get mine started even though i told you were its at. for one of them you have to press the defroster button and wait a certain amount of time before you crank the motor or else it wont crank.
Old 10-19-2007, 05:47 AM
onenonly009's Avatar
Default Re: good place to hide a kill switch... (JKGONZALEZ3)
you should make it so u need 2 people to turn a special key at the same time
Old 10-19-2007, 07:45 AM
p nut's Avatar
Go Transporter style and get an ignition code keypad system.
Old 10-19-2007, 08:02 AM
KickStart2323's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKGONZALEZ3 &raquo;</TD></TR><TR><TD CLASS="quote">ill tell you mine cause you never get mine started even though i told you were its at. for one of them you have to press the defroster button and wait a certain amount of time before you crank the motor or else it wont crank.</TD></TR></TABLE>
can i ask how you did that?...so dose the defroster still work or is it a fake button for the killswitch?
Old 10-19-2007, 08:47 AM
jdm Ef-9's Avatar
Default Re: good place to hide a kill switch... (KickStart2323)
got mine @ the ac button...sleeeeeeeper
Old 10-19-2007, 09:04 AM
ef9robert's Avatar
i like this :-)
Old 10-19-2007, 09:05 AM
EL Vap133's Avatar
Default Re: good place to hide a kill switch... (jdm Ef-9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm Ef-9 &raquo;</TD></TR><TR><TD CLASS="quote">got mine @ the ac button...sleeeeeeeper</TD></TR></TABLE>
Unless the thief breaks in on a hot/warm day.
Old 10-19-2007, 09:16 AM
traxxasx's Avatar
Mines the ciggerette lighter..BAHAHA you cant start it without the ciggerette lighter pushed in....
Im sure noone has this or even knows..well now they do owell..
AHha better have a ecu with you 2.
Old 10-19-2007, 09:21 AM
JG90CRX-Si's Avatar
Default Re: good place to hide a kill switch... (EL Vap133)
I did mine a while back and although I won't give the location, I have to turn into a pretzel to turn it off/on. Sometimes I forget it's on and crank the ignition and in a second or two the car turns off.
It's in a great place that's not visible and still easily missed with a flash light.
Thanks H-T for the great write up.
JG
Old 10-19-2007, 03:39 PM
its gonna be on the fuel pump. i had a friend rig it up to the ignition, than it fried his harness, so i figured i'll call that one skip.
someone else i met had a magnet switch in his dash. you just put it next to the panel to get it started, but i haven't been able to find anything like that, or even a specail key switch for that matter
Old 10-19-2007, 03:51 PM
ITR640's Avatar
I dont have one but....
I like the idea of using a preexistinf switch or button. YOu could even get a foglight switch or cruise switch and use it to be your kill switch.
Or maybe that button that makes that little JDM parking pole thing work and use it as a kill switch.
Old 10-19-2007, 04:12 PM
tougetuned_ef's Avatar
Default Re: (ITR640)
i heard one time of a guy rigged up a click pen in his ceter console so you have to click the pen once to start the car. i know that if was to try to steal a car i wouldnt think to click the pen once to start it. jsut think like a car thief and you will come up with something creative. i met a guy at a meet who put on of those key pads in and he said not even 3 days after he put it in someone tried to steal his car and couldnt do it. it was set up so if you try to take the keypad off it would never start.
Old 10-19-2007, 04:51 PM
grog's Avatar
Default Re: (tougetuned_ef)
some<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIXINinthe805 &raquo;</TD></TR><TR><TD CLASS="quote">someone else i met had a magnet switch in his dash. you just put it next to the panel to get it started, but i haven't been able to find anything like that, or even a specail key switch for that matter</TD></TR></TABLE>
I've heard of using "home security" switches like for a window, its 2 magnets that when placed together complete the switch. so you hide one of the magnets behind something, dash,carpet, or anywhere . to "flip the switch" you stick the other magnet there. when you park take the magnet with you
I believe there are some security write ups if you search, much more detailed than the above
Old 10-19-2007, 05:16 PM
KrenzyRyan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef dino &raquo;</TD></TR><TR><TD CLASS="quote">You can make a switch to control your mothers ******* just be creative with where your putting these switches. </TD></TR></TABLE>
Thats just weird
Old 10-19-2007, 05:24 PM
Torque Junkie
Trakhor's Avatar
If I told you I'd have to "kill" you.
General rule of thumb is put it in plain sight but not obvious.
I knew a guy who rigged up a relay to his "power antenna" feed on his radio. He turned the key on then the radio, then he could start.
Old 10-24-2007, 03:51 PM
Default Re: (grog)
the home security peice souunds like it makes more sense. would something like that wire up with a 12 volt system though?
Old 10-24-2007, 04:33 PM
Tippyman's Avatar
Default Re: (MIXINinthe805)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIXINinthe805 &raquo;</TD></TR><TR><TD CLASS="quote">the home security peice souunds like it makes more sense. would something like that wire up with a 12 volt system though?</TD></TR></TABLE>
If it can handle house voltage, it can certainly handle 12v.
Old 10-24-2007, 04:50 PM
Fuzzy Rhubarb's Avatar
Sounds like a job for some Microchip PICS.
Old 10-24-2007, 05:20 PM
Wes V's Avatar
Default Re: (Fuzzy Rhubarb)
Here is a link to a page that shows hiding a magnetic reed switch;
http://www.performanceforum.com/bob/bob6/bob6.html
Wes
Old 10-24-2007, 05:22 PM
Default Re: (Wes V)
Wire up a fingerprint reader.
Quick Reply: good place to hide a kill switch...
