How can you tell if your wheel bearing is going out?
Old 06-14-2007, 05:40 PM
dj-t's Avatar
Default How can you tell if your wheel bearing is going out?
I have a 90 civic hatch and for the last couple of weeks my car sound like I am riding on some off road mud tires. One of my friend says that it is a sign of my wheel bearing going out. Is he right? I just want to confirm this before I start taking things apart. Thanks
Old 06-14-2007, 05:46 PM
Tyson's Avatar
Default Re: How can you tell if your wheel bearing is going out? (dj-t)
yep.
jack the corner up, turn the wheel with your hands. you should hear the noise. try not to confuse it with the brakes dragging tho.
forget what ppl say about shaking your wheel. you should do it anyway to check your balljoints. but its not the way to check wheel bearings.
Old 06-14-2007, 06:01 PM
dj-t's Avatar
Default Re: How can you tell if your wheel bearing is going out? (Tyson)
Are you saying that it should sound like bad or worn out brakes if I turn it. I'll try that out now.
Old 06-14-2007, 06:04 PM
Tyson's Avatar
youll know. itll sound rough, you might feel it too.
compare with the other side.
Old 06-14-2007, 06:22 PM
dj-t's Avatar
Found it, passenger rear bearing is bad like you said it sounds rough. Thanks for your help Tyson.
Old 06-14-2007, 11:27 PM
Tyson's Avatar
and THATS the proper way to diagnose a bad wheel bearing.
Old 06-14-2007, 11:40 PM
crx22's Avatar
You can also tell by driving the car and loading each side by turning the wheel turn left and it loads the right side and vice versa....use your ears and tell front to back. Then you can double check once you get an idea where....if you have done it a few times you can tell which one just by driving.
Old 06-14-2007, 11:50 PM
cr-x-91's Avatar
true but the cops will get you b4 u find the bad bearing..
Old 02-07-2008, 04:05 PM
redsi89's Avatar
Default Re: (cr-x-91)
ok so i'm having trouble with mine too. when i turn to the left it gets quieter and the left gets worse. is myt left bearing bad?
Old 02-07-2008, 04:21 PM
mullet eater's Avatar
Default Re: (redsi89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redsi89 &raquo;</TD></TR><TR><TD CLASS="quote">ok so i'm having trouble with mine too. when i turn to the left it gets quieter and the left gets worse. is myt left bearing bad?</TD></TR></TABLE>
It sounds like your left sides bad. If you can put it up on a lift and have somebody drive it in the air you should be able to here it.
Old 02-07-2008, 04:42 PM
19cougar68's Avatar
i heard you can also test the wheel bearing by spinning the wheel and holding the spring, if the spring vibrates then thats the wheel bearing that needs to be replaced
Old 02-08-2008, 06:03 AM
Hondaisok's Avatar
Can you test the front tires this way? I would assume that you need to put the tranny in neutral, but can you spin the tires fast enough on the front to diagnose a bad wheel bearing?
Jamezvtec
Honda Civic (2001 - 2005)
06-11-2009 04:43 PM
sicivic
05-07-2004 06:05 AM
crxtreme27
10-03-2003 02:58 PM
vtecdc2
09-28-2003 04:34 AM
bus stop
19
04-22-2003 12:18 AM
Quick Reply: How can you tell if your wheel bearing is going out?
