My windshield wipers are acting funny.... any ideas?
Old 05-20-2007, 05:31 PM
jdmturbo1127's Avatar
Default My windshield wipers are acting funny.... any ideas?
Ok, so my windshield wipers have been acting a little strange lately! When they are on the slowest setting, they dont make a full sweep to the top of the windshield? They pause at different areas on the windshield, sometimes halfway, sometimes a quarter, and sometimes at like three quarters of the windshield. Has anybody had this problem? I hope you can understand what I am talking about..... Anyways, if you have had this problem, please let me know what the heck is going on! Thanks
Old 05-20-2007, 05:48 PM
eskimo10's Avatar
It sounds to me like the windshield wiper motor is going out. Happened to me a few years back, my symptoms were a bit different though. Mine would not stop or wouldn't turn on, and I only had one setting that would work.
Old 05-20-2007, 06:37 PM
H-T White Ops
NOFX's Avatar
I have a similar problem... possibly the same.
I turn my wipers on the lowest setting. The wipers go up, and then randomly stop, usually halfway up or to the top. They might come back down if I wait a few seconds.
I swapped out the interior wiper switch for another one and it still had the same problem. So it's not that.
It's going to be either the wiper motor or the intermittent control relay (which is in the integrated control unit behind the fuse panel).
I know before when I've heard of this problem it usually i the wiper motor. I'm not exactly sure why it would be though (not familiar with the mechanics) since it makes more sense to me for it to be the relay.
Old 05-20-2007, 06:42 PM
Civicman86's Avatar
Default Re: (NOFX)
I'm having the same problem. I have yet had time to look into it. If you all find the fix PM me the answer:
Old 05-20-2007, 06:45 PM
Ek Forever y0!
Libertariat's Avatar
Default Re: (Civicman86)
I got $10 that says its the intermittent control relay. But replacing the motor might be an easier/cheaper fix.
Old 05-20-2007, 06:56 PM
H-T White Ops
NOFX's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">I got $10 that says its the intermittent control relay. But replacing the motor might be an easier/cheaper fix. </TD></TR></TABLE>
New from Honda at least the relay is cheaper (about $56 compared to $150). The motor I'm hoping will be easier though since I think that's the issue as it so often is.
I tried to buy a motor from an Si that was being parted out but the guy didn't get back to me after first being interested in selling it to me.
Old 05-20-2007, 07:13 PM
The thing is it just does it on the first setting. Once I go into the higher settings, They work just fine. So to me I wouldnt think it was the motor... maybe Im wrong? Ill try the control relay first and see what happens. All I know is that I am tired of having my wipers on high speed when its only sprinkling outside
Old 05-20-2007, 07:29 PM
Civicman86's Avatar
Default Re: (jdmturbo1127)
I think its the relay too. on the first click (delayed one) it will go then stop at the top then go down.
On the low or high setting they work fine. Also when I push down on the lever it will stop whenever i let off no matter where the wiper is, where usually it will do one full cycle then stop.
Old 05-20-2007, 08:07 PM
H-T White Ops
NOFX's Avatar
I would think that makes sense too... but it seems that the usual solution actually is to replace the motor.
Old 05-21-2007, 10:30 AM
That is EXACTLY what mine is doing to!
Old 05-25-2007, 06:48 PM
eskimo10's Avatar
It's been a few days so I don't know if y'all got your wipers working again, but when my motor started acting up, it would work on some settings but not on others and then change the settings it would work on randomly. Pretty much had a mind of its own, a lot like what you guys are describing. I went to a junk yard picked up a motor for $50 and replaced it in an hour or w/e and she's good to go. I would say that the motor is the easiest way to go with it. But then again thats just me and I'm no professional
Pilotperson
07-27-2016 05:33 PM
fenix4o9
Honda Civic (2006 - 2015)
03-28-2010 10:01 AM
MikeDawg
07-18-2007 02:03 PM
FTW913
12-14-2005 07:47 PM
Dacalac
02-24-2005 11:57 AM
Quick Reply: My windshield wipers are acting funny.... any ideas?
