Easy but not... Rear seat removal: 88-91 civic hatchback
Okay, these are the fold-down type seats in the hatchback. Much different than the 4-door type that just comes right out. I removed the black plastic spacers on the sides of the seats and they will not slide out. I'm tryin not to damage the paneling (which is what I'm going for to put in my car). These seats will not come out. What am I not doing? There are no bolts, screws or keepers that I can see. Do I need any specific tools?
Re: Easy but not... Rear seat removal: 88-91 civic hatchback (D16Cowboy)
nope no special tools, just remove the two black plastic "C/E" clips and spread the two halves apart in the middle and the top back rests should come out then take off the 12mm bolt and that's it.
remove this "E/C" clip
now it removed
push the seat to the side
then remove
then do the other side, after that remove this bolt and you should be good
Modified by EF001282 at 12:36 AM 4/29/2007
now it removed
then remove
Location: Commonwealth my ass This is the communist state, VA, USA
1 Post
Re: Easy but not... Rear seat removal: 88-91 civic hatchback (EF001282)
Good job EF001282, not very often that you see a single response post that's helpful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Cowboy »</TD></TR><TR><TD CLASS="quote">Thanks so very much... I'm going to get it done right now </TD></TR></TABLE>
sure no prob, I was bored last night so I felt like helping.
Hatch It
03-15-2005 06:01 PM
