16/17 inch Honda wheels that would fit 97 Accord?
Old 04-14-2007, 03:11 PM
Secret Chimp's Avatar
Default 16/17 inch Honda wheels that would fit 97 Accord?
I'd like to upsize my tires, but instead of dropping several hundred on new wheels, I'd like to use stock Honda steelies or alloys of 16 or 17 inch diameters. Are there any wheels in that size range that would fit the bolt and hub pattern of a 97 4 cyl?
Old 04-14-2007, 04:07 PM
corrosive23's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (Secret Chimp)
You can use the 97 Special Edition Alloy wheels.
Old 04-14-2007, 04:24 PM
slomob18b's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (corrosive23)
Try this:
https://honda-tech.com/zerothread?id=1938439
Can't think of any stock Honda wheel that is 17" and has a 4x114 bolt pattern. Maybe the factory option ones, but they are probably expensive if they exist.
Old 04-14-2007, 05:12 PM
SkimN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by corrosive23 &raquo;</TD></TR><TR><TD CLASS="quote">You can use the 97 Special Edition Alloy wheels.</TD></TR></TABLE>
Special Edition wheels are only 15"
Old 04-14-2007, 05:24 PM
JDM_DC4_Fanatic's Avatar
just go to a tire place, and ask them for 17x6.5 steelies that are 4x114.3 bolt pattern with a honda hub bore. There are no 17" 4 bolt OEM honda wheels. but, there should be some kind of aftermarket steelies avaliable.
Old 04-14-2007, 05:34 PM
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (JDM_DC4_Fanatic)
I didn't realize this was possible. Any idea on what the per-wheel cost would be?
Old 04-14-2007, 07:03 PM
SneezinCD5's Avatar
16" CL wheels
15" EX Wheels
Old 04-14-2007, 07:40 PM
Honda_Accord's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (SneezinCD5)
Whats the drop on that sneezin? (the first few pics)
Old 04-14-2007, 09:26 PM
SneezinCD5's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (Honda_Accord)
I've got full Omni coilovers. If I were to guess id say 3-3 1/4"
2 low for daily driving (Just lowered it for the C8's and to do a mini shoot). Car is currently down for new interior turbo/engine build.
Here are some pics with 16" C8's. (Same drop as the CL wheels)
Modified by SneezinCD5 at 1:58 AM 4/15/2007
Old 04-14-2007, 10:03 PM
ate my pixel
Twixle's Avatar
Why would you want to put on 17" steelies with low profile tires? It seems to me that the benefits on that are horribly outweighed by the consequences.
Old 04-14-2007, 11:58 PM
SuShiBoiiii's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (accord2021)
or get some 16 itr wheels
Old 04-15-2007, 12:36 AM
slomob18b's Avatar
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (SuShiBoiiii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">or get some 16 itr wheels </TD></TR></TABLE>
He's looking for wheels with a 4x114 bolt pattern
Old 04-15-2007, 09:03 AM
I checked at work, we can get them for 75$ CDN each
Old 04-15-2007, 09:06 AM
Black Ex Coupe's Avatar
Damn sneezin your car looks great on any wheel.
Old 04-15-2007, 09:54 AM
Default Re: 16/17 inch Honda wheels that would fit 97 Accord? (slomob18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomob18b &raquo;</TD></TR><TR><TD CLASS="quote">
He's looking for wheels with a 4x114 bolt pattern </TD></TR></TABLE>
i think momstaxi has 16's itrs on a 4x114 bolt pattern on his accord, but i could be wrong, i cant find his car with them on it. looks hella sweet though.
https://honda-tech.com/zero...age=2
scroll a bit until you see them on his accord , awesome lookin car, i belive those are 16's
Old 04-15-2007, 10:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Accord &raquo;</TD></TR><TR><TD CLASS="quote">i think momstaxi has 16's itrs on a 4x114 bolt pattern on his accord, but i could be wrong, i cant find his car with them on it. looks hella sweet though.
scroll a bit until you see them on his accord , awesome lookin car, i belive those are 16's</TD></TR></TABLE>
Those are 96 itr wheels. They are 15" wheels and the only 4x114.3 ITR wheel.
Old 04-15-2007, 11:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Ex Coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Those are 96 itr wheels. They are 15" wheels and the only 4x114.3 ITR wheel. </TD></TR></TABLE>
Old 04-19-2007, 08:00 PM
SneezinCD5's Avatar
Default Re: (Black Ex Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Ex Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Damn sneezin your car looks great on any wheel. </TD></TR></TABLE>
Thanks Gotta get a new set of wheels soon. Getting tired of the Cl wheels
Old 07-08-2013, 06:39 PM
xx_the_piper_xx's Avatar
I know this thread is super old, but I just got a '95 Accord LX 4cyl and purchased some 15x6 114.3x4 6-spoke rims from a 2000 Accord. The car is stock height and after trial fitting the rims with the car jacked up in the air and no tires, clearance was pretty tight on the inside. In the rear, the wheels get close to the lower trailing arm and spring assembly, and in the front it's close to the spring assembly. Does anyone know if rims for the '00 won't fit on the '95? If I had tires on the wheels and put it on the ground, do you think more room would open up?
Also, would the 16" CL rims featured in this thread work on the '95 without wheel spacers? They look good on the '97 in the pics, can the owner of that car verify if wheel spacers were used and or if there were any inner clearance problems? This is a daily driver and I don't plan on lowering it.
Thanks in advance for any help!!!
JmR2004Acura
12-28-2017 10:30 AM
papsgarage
Honda CR-V & Element
06-19-2015 12:32 AM
perry2929
02-10-2014 08:44 PM
jrunager
10-04-2012 06:22 AM
ragnaroek
11-07-2006 01:41 PM
Quick Reply: 16/17 inch Honda wheels that would fit 97 Accord?
