Supertech SPR-H1002D valve springs with Toda Spec B?
Old 02-27-2007, 02:30 PM
psegs80's Avatar
Default Supertech SPR-H1002D valve springs with Toda Spec B?
Any experiences using Supertech SPR-H1002D valve springs with Toda Spec B cams in a B18C-R?
Pat
Old 02-27-2007, 07:08 PM
psegs80's Avatar
Default Re: Supertech SPR-H1002D valve springs with Toda Spec B? (psegs80)
I'm trying to find out from experiences if they work well together and how long you have been using them?
Old 02-27-2007, 10:01 PM
FSAE
92TypeR's Avatar
Don't have much experience with the 2D kit. The DR is plenty of spring for any cam you can find on the market. If you havn't already purchased the valvesprings, you might as well get the DR since they are the same price.
I don't remember what the seat pressure is of the original SuperTech springs, but we use them exclusively on our builds and havn't had trouble with any SuperTech products.
I believe the 2D has a seat pressure of 70lbs at 33mm, which should be good for TODA B's. DR's are 90lbs if memory serves correct.
Old 02-27-2007, 10:06 PM
Combustion Contraption's Avatar
Default Re: Supertech SPR-H1002D valve springs with Toda Spec B? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
I believe the 2D has a seat pressure of 70lbs at 33mm, which should be good for TODA B's. DR's are 90lbs if memory serves correct.</TD></TR></TABLE>
Speak in inches, you havent crossed the candian border yet!
Old 02-28-2007, 08:09 AM
psegs80's Avatar
Default Re: Supertech SPR-H1002D valve springs with Toda Spec B? (Combustion Contraption)
I am Canadian but inches is fine! My concern is that the Toda spec b need a softer spring because of the ramp up and down...toda springs have 190lbs at 12.5mm and Supertech 190lbs at 12mm? The seat pressure is 70lbs on the Supertech and Toda? Toda Coil bind is at 12.9mm lift and supertech is something crazy like 19.5mm or so!
I just want reliability cause I will be racing this engine 1hours a week for 4 months!
Pat
Old 02-28-2007, 10:19 AM
TwoRedEGgs's Avatar
We have a ITR motor that we run Toda B's with supertech ValveSprings. I Pretty sure I am running the DR setup but i cant be 100% since its been a while since i put them in and have since bought more for other setups. Either one will work fine but you might as well get the DR set up since its not too much more if anything !
Old 02-28-2007, 10:24 AM
psegs80's Avatar
Default Re: Supertech SPR-H1002D valve springs with Toda Spec B? (TwoRedEGgs)
Toda Valve Springs
Variable or Linear: Variable
Seat Pressure: ???
Max Lift: 12.5mm
Coil Bind: 12.9mm
Pressure @ 12.5mm/.492" lift: 190lbs
Supertech B-Series Valve Springs PN SPR-H1002D-KIT
Variable or Linear: Linear
Seat Pressure: ???
Max Lift: 12.5mm
Coil Bind 19.5mm
Pressure @ 12mm/.472" lift: 190lbs
Supertech B-Series Valve Springs PN SPR-H100DR-KIT
Seat Pressure: ???
Max Lift: 14mm
Coil Bind ???
Pressure @ 14mm/.551" lift: 266lbs
I'm curious, does excessive spring pressure cause cam and valvtrain damage like Toda claims?
Old 02-28-2007, 03:42 PM
psegs80's Avatar
does anyone know the install height of the Supertech 2D springs? I know Toda's are 1.325" and Larry From Endyn Recommends 1.400" install height with the spec b cams?
Old 02-28-2007, 04:58 PM
psegs80's Avatar
Martin from Supertech told me that the installed height is 33.50mm/1.319" which is close to Toda's 1.325"...my concern is that Larry from Endyn recommends 1.400" with the Toda spec b and c's cams?
Pat
Old 05-05-2007, 03:40 PM
99hondacura's Avatar
Location: down the street,bythe river in the van, co, united states
are this valve springs you talking about are they the dual spring or the single?
Old 05-06-2007, 10:09 AM
psegs80's Avatar
Default Re: (99hondacura)
They are dual...I have had them in for the last 2 weeks and I haven't had any problems so far...Mustang dyno I made 203whp at 8400 with my spec b's
Pat
Old 05-06-2007, 11:22 AM
The Old One
ENDYN's Avatar
Default Re: (psegs80)
Larry from Endyn doesn't recommend using Toda spec B or spec C cams regardless of valve spring choice....
Any cams that regularly break valvetrain components and timing belts should be avoided...
Old 07-28-2007, 06:59 AM
bks84's Avatar
Default Re: (ENDYN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ENDYN &raquo;</TD></TR><TR><TD CLASS="quote">Larry from Endyn doesn't recommend using Toda spec B or spec C cams regardless of valve spring choice....
Any cams that regularly break valvetrain components and timing belts should be avoided...</TD></TR></TABLE>
Then what do you recommend?
baysic r
06-29-2009 11:49 PM
ITR.#1446
07-30-2008 06:58 AM
JDM97dc2R
12-29-2005 09:15 AM
Renegade
08-04-2004 12:40 PM
Quick Reply: Supertech SPR-H1002D valve springs with Toda Spec B?
