AT trans slipping / Po730 code - wrong gear ratio after gets warmed up
Old 02-17-2007, 12:10 PM
hondarsw's Avatar
Default AT trans slipping / Po730 code - wrong gear ratio after gets warmed up
2001 Civic EX with 130,000 miles on it. Fluid flushed once at 75k. Trans slips excessivly and pulls a P0730 code. Fluid is brnt
Any hope ?
Thanks in advance
P.S. Looks like maybe a trans is in order - if so - DOes anyone have a good line on transmissions. Honda is on back order with no light in sight.
I always thought Hondas were bulletproof and have worked on many over the years - never seen a trans go out at 130k - why me ?
Old 02-17-2007, 12:52 PM
Schumacher '10 WDC
Tadehi's Avatar
Default Re: AT trans slipping / Po730 code - wrong gear ratio after gets warmed up (hondarsw)
I have heard so many complaints about the automatic transmission in the '01 civic's its not even funny. Luckily I drive manual. By fluid burnt I assume its black or very dark? I am not a transmission expert but your guess sounds right. You could take it to a transmission repair place, and have them disassemble and reassemble it, but that will cost you loads, sorry. More will chime in don't worry.
PS. Welcome
Old 02-17-2007, 01:46 PM
Curiouz_G's Avatar
the auto trannies in the 7thgen's were one of the crappiest ever made by honda if not THE crappiest
1yesfan
03-12-2015 02:31 PM
lovedam
09-09-2011 04:21 PM
ldyjam
06-22-2011 04:12 PM
ej1project
09-07-2010 08:26 PM
AnAccordIsForever
01-08-2006 08:10 AM
Quick Reply: AT trans slipping / Po730 code - wrong gear ratio after gets warmed up
