Exedy cerametallic clutch stage 2
Old 08-30-2006, 02:21 PM
vlc92189's Avatar
Default Exedy cerametallic clutch stage 2
Has anyone had any experience with this clutch? and my car is a daily driver.. should i get a thick disk or thin? thatss the only part im worried bout..
Old 08-31-2006, 07:44 PM
818SpoonITR's Avatar
Default Re: Exedy cerametallic clutch stage 2 (vlc92189)
Get a Exedy stage 2 full face clutch
Old 08-31-2006, 07:46 PM
vlc92189's Avatar
whats a full face?
Old 09-04-2006, 01:11 PM
Default Re: (vlc92189)
EXEDY racing clutches with organic friction materials utilize only premium materials to provide maximum resistance to slippage and burst.
EXEDY full face disc organic clutches can also handle modified engines due to the increased clamp loads.
Drivability with EXEDY organic clutches is similar to that of stock clutches. Pedal efforts will be slightly higher due to the higher clamp loads.
As with all EXEDY clutch discs, EXEDY organic clutches feature high capacity spring center dampers designed to reduce drive train shock and impact.
dominicanboi215
02-22-2009 07:02 PM
IgnitionZ055
11-11-2008 05:12 PM
EARLdaSQUIRREL
10-12-2008 10:23 AM
Dave_yd
03-26-2008 04:23 PM
turbotime
10-11-2004 10:24 PM
Quick Reply: Exedy cerametallic clutch stage 2
