Switching from Conventional Oil to Synthetic Blend.
Hey guys, I have a few questions concerning the oil I'm about to put in my F23A4. Since 25k miles (There's currently 63k miles on the block), since I've had it that is, I've put just regular old oil in the car. My last oil change I put in Castrol GTX with an K&N Oil filter. I was wondering whether there would be any problem with switching to Castrol GTX Synthetic Blend and whether it would cause any problems to my engine? I plan on switching to Full Synthetic once I've put in Synthetic blend for about 20k miles or so? Is this ok?
Re: Switching from Conventional Oil to Synthetic Blend. (Corruption)
screw the blend and just swap right to full synthetic. there is no issue with doing that.
most "blends" are like 80% conventional oil anyway, a marketing scam.
Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">there is no probelm changing you roil. doesnt matter if its synth, blend or dino oil.</TD></TR></TABLE>
ONLY if the motor is fully broken in
you don't have to step up with synblend, and yes B's right about syn blend, the ratio is around 8:2 if not lower.
most car doesn't need syn. oil, the dino oil today is so much advance than old oil formula from past.
Re: (Corruption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corruption »</TD></TR><TR><TD CLASS="quote">iamhead, what the hell are you talking about? All I want to know is if it's safe to use this oil that I just bought and then use full syn next time?</TD></TR></TABLE>
Yes, it is safe. I'm not sure why you want to spend more money than you have to but, yes, it's safe.
Re: Switching from Conventional Oil to Synthetic Blend. (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">screw the blend and just swap right to full synthetic. there is no issue with doing that.
most "blends" are like 80% conventional oil anyway, a marketing scam.</TD></TR></TABLE>
got any links to that percentage of dino-synthetic ratio? just curious...
Re: (Corruption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corruption »</TD></TR><TR><TD CLASS="quote">Would there be any problem with using syn blend this oil change and then throw in full syn next time? What are you currently running in your f23a1 notorious?</TD></TR></TABLE>
you can switch from blend to full synth next change no worries.
I am using Royal Purple 5w30 full synthetic, but that's because I've got a built motor and boost the **** out of it. I ran it on dino oil for breakin, started w/ 10w40 for 3 oil changes (1st one within 20 miles!), went to 10w30, and finally after 3k+ miles changed to full synth.
