Steering Wheel Removal. 2000 Accord SE.
Old 08-03-2006, 12:18 PM
garaged_Si's Avatar
Default Steering Wheel Removal. 2000 Accord SE.
Anybody Know how to remove the steering wheel? couldnt find the topic about this so i just started new Topic's. Want to install a quick release but not really sure how to remove the steering wheel. Any help will be appreciated, Thanks.
Old 08-03-2006, 12:35 PM
philadd's Avatar
Default Re: Steering Wheel Removal. 2000 Accord SE. (garaged_Si)
1. Make sure to park the car with wheels straight.
2. Disconnect negative battery cable, and then positive cable.
3. Remove access plate from bottom of steering wheel. Unplug the yellow 2-pin connector.
4. Remove the access panels from each side of the steering wheel, then remove the torx bolts. Pull off the airbag module and set it in a safe place.
5. Unplug the connectors for the cruise control and horn.
6. Remove the steering wheel bolt. Remove the steering wheel using a steering wheel puller.
Old 08-03-2006, 03:12 PM
Crono139's Avatar
Default Re: Steering Wheel Removal. 2000 Accord SE. (philadd)
http://www.filtsai.com/accord/...x.php
Old 08-03-2006, 11:43 PM
garaged_Si's Avatar
Thanks, The pictures will be helpfull.
Old 08-05-2006, 10:21 AM
garaged_Si's Avatar
htwitr01
07-08-2010 07:13 PM
ek9tl
02-22-2007 10:34 AM
Jdmdc4ls
04-24-2006 12:15 PM
Quick Reply: Steering Wheel Removal. 2000 Accord SE.
