Timing belt symptoms?
Old 07-26-2002, 08:08 AM
aqttran's Avatar
Default Timing belt symptoms?
Does anyone knows what are the symptoms of the timing belt failure? Got an 89 Accord LXi. Engine stopped suddenly on the highway and never start up again. Dealer said it may be the timing belt. Want to get a second opinion. Thanks
Old 07-26-2002, 08:32 AM
Chiovnidca's Avatar
Default Re: Timing belt symptoms? (aqttran)
That's a pretty good symptom. If you don't beleive the dealer, ask to see it before you authorize any work.
Old 07-26-2002, 09:32 AM
Power1Pete's Avatar
sounds like it is. btw, when was the last time you change your timing belt? they usually last around 60K miles.
Old 07-26-2002, 01:58 PM
New User
88_SC_CRX_Si's Avatar
There is a good possiabilty that some valve damage occured, depending on what rpm you were at. Sooo, that way you won't be too surprized, about the bill you get for replacing the bent ones.....
Old 07-26-2002, 08:19 PM
New User
BreakStuff's Avatar
ok girls.. heres a tip...
remove the oil filler cap on the valve cover.. shine a flashlight in the hole and visually see if the valvetrain is moving while cranking the motor..
no movement = broken T-Belt..
Jonathang
09-18-2011 10:55 AM
ShinobiLude
02-15-2007 09:03 AM
projekte36
06-24-2004 11:46 PM
smkngsr
06-30-2002 08:53 PM
Quick Reply: Timing belt symptoms?
