95 accord timing belt replacement
95 accord timing belt tensioner
i was just wondering if there is any write up for accord timing belt replacement because i cant see to find any..... all i really need to know is how to take tension off the tensioner pulley(which seems like if you wrench one of the bolt thats on the tensioner pulley) and also setting it tdc and where the tdc marks are..... thanks
Modified by xiLLtegRax at 4:41 PM 5/20/2006
Re: 95 accord timing belt replacement (xiLLtegRax)
search is your friend... since u weren't specific on the engine, i'll just ***ume that u gotz da F22B2 engine
edit: it's down right now... save n refresh @ a later time, mebbe?
something to look for while you are in there...
here's the startup point w/ that link that's not currently available rite now
you can also go thru the free online manual on http://www.autozone.com
it's better than nothing, i guess... chiltons/haynes type of deal
there were also a few .pdf files of FSM/Helms type manuals floating around but I can't find them right now 4 u (my searching skills suck)
Re: 95 accord timing belt replacement (ricebike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricebike »</TD></TR><TR><TD CLASS="quote">
there were also a few .pdf files of FSM/Helms type manuals floating around but I can't find them right now 4 u (my searching skills suck) </TD></TR></TABLE>
http://www.hondahookup.com/manuals/ for pdf manuals. you gotta free register to download.
peace
peace
Re: 95 accord timing belt replacement (LSV84)
i was just wondering i got the instruction for the timing belt from alldata. but im wondering how do you adjust the tension for the belt that goes aroudn the camshaft pulley?? alldata said something about installing some long bolt on this hole to hold the adjustment arm but i dont really have a bolt that long. if anyone knows how to adjust the tension on timing belt for this car. please let me know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xiLLtegRax »</TD></TR><TR><TD CLASS="quote">someone has to know how to adjust this dam thing</TD></TR></TABLE>
Push the tensioner up till you can shove the 'long' side of the T-belt inwards about 1/2 inch with your finger while it's under tension.
You can also turn the crank pulley a few teeth counter clockwise till all the slack is gone from the belt, then lock down the tensioner; Leave a little slack in the balance shaft belt or it will howl; about 1/8 inch free slack between the crank pulley and rear 'oil pump' pulley.
H-T Order of Merit
LSV84, just so you know, we're not actually allowed to post links to downloads of the PDF service manuals.
xiLLtegRax, To adjest the tension, loosen the adjusting nut (located just above the crank pulley) 1 turn. Then turn the crankshaft CCW until you move 3 teeth on the camshaft pulley. Then tighten the adjusting nut back down.
jwonger
01-18-2024 04:23 AM
Integacivic
12-02-2004 03:44 PM
