best vtec oil?
best vtec oil?
Does anyone know what the best oil woiuld be to run on my 130000 mile h22a1 is royal purple and good ??please help what's good?
Re: best vtec oil? (93h22a1vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22a1vtec »</TD></TR><TR><TD CLASS="quote">mobil 1 ftw</TD></TR></TABLE>
x2
x2
Re: best vtec oil? (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 »</TD></TR><TR><TD CLASS="quote">what makes the honda s2000 filter so much better?</TD></TR></TABLE>
It's JDM boooiiiiiii!!!!!!!!!
There is no reason to change your oil anywhere near 2-3000 miles. You're wasting your money. Synthetics last much longer - in the 5-10,000 mile range. Do an oil analysis if you don't believe it. Just get a good synthetic like mobil 1 or the german castrol.
It's not made by Fram and its OEM
Re: best vtec oil? (DIRTYsouthBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 »</TD></TR><TR><TD CLASS="quote">
It's JDM boooiiiiiii!!!!!!!!! </TD></TR></TABLE>
You're a *** and have no idea what you're talking about
Re: (BlueLude 94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude 94 »</TD></TR><TR><TD CLASS="quote">Greedy just released an oil that is strictly ment for VTEC engines.</TD></TR></TABLE>
any more info on that?
Re: (BlueLude 94)
HAHAHA.
HAHAHA.
Re: best vtec oil? (darkstar1440)
Royal Purple here. Call me obsessive but i change my oil every 2500-3500miles with partial quart top offs. h22's are notorious for oil consumption. Valve seals, and cam seals will help. But even from the factory they burn oil. I say check your oil regularly, make sure you're lubricated, top off as needed, and at least change at the recommended interval 3750miles unless you run synthetic then as yield said 5-10kmi. Measuring how much oil is left in your engine between intervals will give you a better idea of how much oil your motor burns or leaks (that's beyond the scope of this discussion). I have seen approx 1qt per 1000mi, of consumption, with conventional oil and half that for royal purple at least on my vehicle. So i think top offs are especially important.
Send some samples to blackstone for analysis. Let a professional determine how long you have before changing your oil.
Re: best vtec oil? (98vtec)
after i pass 3k, i start thinking about changing it. sometimes i keep it in there until over 4k. but i use synthetic. contrare to what some may say, synthetic does break down if you run your engine hard. i was burning a quart every two weeks before i changed my oil last. and that was after about 4,500 miles.
Guest
Posts: n/a
Re: best vtec oil? (honda3431)
i heard about that as well....
Re: best vtec oil? (AnthonyG2003)
ive learned to let everyone else test new stuff then try it
1 Post
i change oil every 8000 miles.
mobil 1 10w30.
i refuse to change oil every 3000 miles.
og poster: what kind of oil have you been using for the past 130000 miles? synthetic in a high mileage motor can lead to some headaches.
mobil 1 10w30.
