Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
replacing head gasket on 94 legend
Old 02-26-2006, 11:07 AM
tnord's Avatar
Default replacing head gasket on 94 legend
well, after having sporatic but reoccuring cooling problems, the source finally reared its ugly head in the form of white smoke out the tailpipe.
i'm pretty mechanically inclined (have built entire engines from a bare block), so i thought i might try this myself. the issue is i've never done any real work on anything but a 4cyl. has anyone here done this and want to offer up some advice, words of encouragement, or words of discouragement?
Old 02-26-2006, 11:36 AM
CmptchAV6's Avatar
Default Re: replacing head gasket on 94 legend (tnord)
here should be all the info you need
http://www.acura-legend.com/vb...65753
Old 02-27-2006, 08:55 AM
Sweet Title
sixfiveoh's Avatar
Default Re: replacing head gasket on 94 legend (CmptchAV6)
i ran into this problem myself, and many told me that getting a fresh motor would be the better path to go
Old 03-03-2006, 04:58 AM
tnord's Avatar
perfect....thanks for the link.
i'm not even going to consider a new motor since i'm just going to turn around and sell it.
Old 03-06-2006, 03:47 PM
tvrsir's Avatar
one suggestion, be carefull with those knock sensors when removing the heads, you tend to hit them with the heads when taking it out. so if i were you i would just remove the sensors first then remove the heads
then install the heads then reinstall the sensor.
ask me how i kow i've broken them
Old 03-06-2006, 04:16 PM
tnord's Avatar
Default Re: replacing head gasket on 94 legend (tvrsir)
i'll remember that....thanks.
i'll be starting on this in the next couple days.
Old 03-15-2006, 06:49 PM
tnord's Avatar
i dunno how you guys work on these cars.....
without a doubt this is the worst car i've ever turned a wrench on. i've never seen so many vacuum lines on a non rotary powered car.
for those of you that have worked on these cars.....is there something attached to the back of the intake manifold that i can't see? i seriously can't tell why it won't come off.
Old 03-16-2006, 07:46 PM
HT White Ops
Kenso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord &raquo;</TD></TR><TR><TD CLASS="quote">i dunno how you guys work on these cars.....
for those of you that have worked on these cars.....is there something attached to the back of the intake manifold that i can't see? i seriously can't tell why it won't come off.</TD></TR></TABLE>
Did you disconnect the PAIR pipe from the PAIR valve on the back of the manifold? (pipe runs from the valve to the driver's side exh. manifold). Also make sure you removed the EGR pipe from the EGR valve mounting bracket to the bottom of the intake manifold.
Old 03-18-2006, 10:06 AM
tnord's Avatar
Default Re: replacing head gasket on 94 legend (Kenso)
it was the EGR that needed to be disconnected. from the side, it didn't look like the intake manifold was connected to it, but obviously, it was.
i still hate working on this thing. out to the garage i go, heads are coming off this afternoon.
thanks.
Old 03-24-2006, 02:44 PM
b16pwrcrx's Avatar
yea a buddy at work did 2 headgasket cars last week, they def look like a pain in the ***. are u gonna take the heads to get milled?
Old 03-27-2006, 09:08 AM
tnord's Avatar
Default Re: replacing head gasket on 94 legend (b16pwrcrx)
nope. i just checked them with a straight edge and feeler guages. they checked out just fine.....so i lucked out a little bit there.
now i'm trying to figure out which knock sensor goes on which cylinder bank. there's a one with a blue wire and one with a gray wire. i'm thinking it probably does make a difference which one goes on which side.
anyone......anyone.....bueller?
Old 03-27-2006, 05:53 PM
HT White Ops
Kenso's Avatar
Fun isn't it? Red/Blue to the driver's side sensor, white to the pass. side sensor. I posted the schematic from the Helms in your thread on A-L.com if you want to check it out. Here's the pic from when I did my Type II head swap a while back.
Old 03-28-2006, 02:10 PM
tnord's Avatar
no, it's not fun.
thanks for replying (in both threads), i'm going back to work on it tonight.
JDMBukLau
11-30-2012 07:30 PM
strike1545
05-24-2010 10:42 AM
romibi6
10-28-2008 06:30 AM
methos713
05-02-2008 08:53 AM
kamira
06-30-2002 01:17 PM
Quick Reply: replacing head gasket on 94 legend
