Dome light wont come on when driver's door is opened (4th Gen)
Old 10-05-2005, 06:04 AM
delguiner's Avatar
Default Dome light wont come on when driver's door is opened (4th Gen)
Hey guys, my dome light nor the open door light on my dash wont come on when the driver's side door opens. The passenger side door works perfectly. How do i check for that? Is there a fuse or something thats not making contact?
Thank you!
Old 10-05-2005, 06:26 AM
Lewdin' Incognito's Avatar
Default Re: Dome light wont come on when driver's door is opened (delguiner)
There's a little black contact switch on the door frame that the door hits when it closes. If it's stuck in then the light won't come on. Probably not that simple, but it's a place to start.
Old 10-05-2005, 06:30 AM
H22a T13's Avatar
This same thing happened to me, It wouildnt turn on with either door opened or by the switch. Untill yesterday when it magicly started to work.
Old 10-05-2005, 08:01 AM
eluder33's Avatar
I just fixed mine the other day! I took the little slider switch off (it in the door jam) and the contacts were a little corroded like a battery terminal. I order to get the part out I...
1. unscrew the assembly with one phillips head screwdriver
2. unplug the connection after you pull out the switch
3. pull appart the slider switch, be careful not to lose the spring!
4.Clean the brass contacts with fine sandpaper or scotch brite.
5. reassemble in reverse order and let there be light!
Old 10-05-2005, 08:14 AM
VisPreludeVtec's Avatar
Default Re: Dome light wont come on when driver's door is opened (matty c)
mine is doing the same....will try this tonight thanks
Old 10-05-2005, 08:19 AM
Honda Sport's Avatar
cool, mine's was doing this also. will try tonight...
Old 10-05-2005, 08:21 AM
mgags7's Avatar
haha
mines not doing it....
but good info matty boy
Old 10-05-2005, 09:19 AM
rawNArsxS's Avatar
mine was doin the same thing...i was actually starting to miss the anoying honda beeps that come on when the door is open lol...ill have to check this out too
Myechtatel
07-14-2013 08:31 PM
jaysin04
11-22-2008 12:44 AM
Silent_Destruct
11-26-2006 07:02 PM
asmallsol
08-27-2006 10:58 AM
fishie
09-19-2002 06:20 AM
Quick Reply: Dome light wont come on when driver's door is opened (4th Gen)
