civic si REAR SPEAKER SIZE?
Old 09-29-2005, 10:13 AM
That Sob's Avatar
Default civic si REAR SPEAKER SIZE?
On a 2000 civic si what are the size of the speakers in the rear deck????
Old 09-29-2005, 10:14 AM
SE7EN3S's Avatar
Default Re: civic si REAR SPEAKER SIZE? (That Sob)
I wanna say 6X9
Check Crutchfield.com
Old 09-29-2005, 10:19 AM
That Sob's Avatar
i idid and it says 6 1/2's will fit and 6x9's so im confused........
Old 09-29-2005, 10:21 AM
cambopheonix56's Avatar
Default Re: (That Sob)
6 x 9. I changed mine out and that was the size. Takes a while to change them tho.
Old 09-29-2005, 10:28 AM
SE7EN3S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by That Sob &raquo;</TD></TR><TR><TD CLASS="quote">i idid and it says 6 1/2's will fit and 6x9's so im confused........</TD></TR></TABLE>
6X9 is probably standard (what's in there). But you can probably get an adapter plate to fit some 6 1/2's.
And what cambopheonix56 said, this could take a while. - I did my 2001 civic and had to take the entire rear interior of the car out
Old 09-29-2005, 10:32 AM
^LORTA^RACING's Avatar
look inside trunk and unbolt the the speaker cover so you can see the speaker size.
Old 09-29-2005, 11:37 AM
gftgrill's Avatar
Default Re: (EJ1^LORTA)
6x9's are in the back. I think 6 1/2's are the size of the fronts.
Old 09-29-2005, 11:39 AM
AutoXer's Avatar
Default Re: (gftgrill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill &raquo;</TD></TR><TR><TD CLASS="quote">6x9's are in the back. I think 6 1/2's are the size of the fronts.</TD></TR></TABLE>
And you can fit a 6.5 in a 6x9 hole.
Old 09-29-2005, 07:35 PM
Default Re: (SE7EN3S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SE7EN3S &raquo;</TD></TR><TR><TD CLASS="quote">
its a bitch.. unless you got some top of the line speakers, i would leave the stock ones in.
Old 09-29-2005, 08:54 PM
EL Vap133's Avatar
Default Re: civic si REAR SPEAKER SIZE? (SE7EN3S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SE7EN3S &raquo;</TD></TR><TR><TD CLASS="quote">I wanna say 6X9
Old 09-29-2005, 08:59 PM
C2daIzZle's Avatar
ah, its not that bad. just make sure your a patient person.. otherwise you might just well put your screwdriver through one of the speakers in anger.. heh :X
Old 09-29-2005, 09:02 PM
As long as I dont have to take out any more Metal Gears
rukawa1one's Avatar
Default Re: (C2daIzZle)
I think all 96-00 civics that came with factory sound system had 6x9 in the rear, my 4 door does for sure
Old 09-30-2005, 09:33 AM
That Sob's Avatar
Thanks for the help guys...when i get my civic back i hopefully be able to upgrade these easy enuff
Old 09-30-2005, 09:56 AM
Ricey McRicerton's Avatar
Default Re: (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">I think all 96-00 civics that came with factory sound system had 6x9 in the rear, my 4 door does for sure </TD></TR></TABLE>
So do the hatches and coupes.
Yes, theyre a PITA to change out.
DonDinero
Honda Civic (2001 - 2005)
01-10-2008 10:54 PM
midas06
Audio / Security / Video
09-20-2004 07:19 AM
Toostinky
11-16-2003 08:13 AM
BluLuder
09-06-2001 02:23 PM
Quick Reply: civic si REAR SPEAKER SIZE?
