will aircraft paint remover dissolve fiberglass?
Old 06-22-2005, 12:14 AM
deadlock32's Avatar
Default will aircraft paint remover dissolve fiberglass?
Just a simple question. I just want to get rid of the paint on som fiberglass and instead of talking all the time to sand it off, can I use paint remover? I am just wondering if it will start to dissolve the fiberglass along with the paint. = ]
thanks in advance.
Old 06-22-2005, 07:11 AM
Flashmn's Avatar
Default Re: will aircraft paint remover dissolve fiberglass? (deadlock32)
I doubt it would, but I'd say you'd get a much better result and a better surface to respray on when you sand it. Dont do it by hand tho
Old 06-22-2005, 06:36 PM
deadlock32's Avatar
Default Re: will aircraft paint remover dissolve fiberglass? (Flashmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">I doubt it would, but I'd say you'd get a much better result and a better surface to respray on when you sand it. Dont do it by hand tho </TD></TR></TABLE>
well, i will be laying down some new fiberglass and such, and im not opposed to sanding it, but it will take a lot more time to sand off the existing paint rather than taking off the paint then sanding it smooth.
Old 06-23-2005, 10:19 AM
underpressure02's Avatar
I am pretty sure you will be okay. I think I used aircraft paint remover when my dad and I did the frame up on the 68 vette. I would have to check what we used.
Old 06-24-2005, 10:22 AM
turbo_b16_ex's Avatar
i would recommend testing it out on a corvette and see what happens. Who here actually likes ls1's?
Old 06-25-2005, 06:03 PM
rioninja's Avatar
If your quick about it, you'll be ok. But leave it on there too long, and it will definatly start eroding the resin.
Old 06-26-2005, 03:50 AM
NitroSign's Avatar
it dissolves body filler in a heartbeat. ive done it before by accident! it turns to mush
Old 06-26-2005, 07:53 AM
alexb16hb's Avatar
Default Re: (NitroSign)
That stuff will make fiberglass start to get soft and mushy!! I wouldnt do it!!
jdmcx
Paint and Body
01-06-2012 11:53 AM
SRd240sx
05-17-2004 04:40 PM
93MR2Turbo
05-04-2004 12:00 AM
daddymaxx
01-27-2004 05:19 AM
deeweezy
08-17-2003 07:19 AM
Quick Reply: will aircraft paint remover dissolve fiberglass?
