Stripped oil plug.
Stripped oil plug.
I just bought a '93 Civic HB and when I bought it home to give it an oil change I found that the oil plug is stripped out. I might be able to unscrew it if I try hard enough, I just wanted to know if anybody knew any tricks that I don't know about to get it off.
Re: (Dimitri_EG8)
That'll work. Thanks. Tried the vicegrips. They just slipped around on the plug like the wrench did. Someone did a real number on it, multiple times.
If whoever did this was stupid enough to not only strip the oil drain plug, but to keep using it and stripping it more and more each time -- now I have to look at every single facet of this car to see what other stupid crap might have been done to it.
Re: (extra cam needed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimitri_EG8 »</TD></TR><TR><TD CLASS="quote">Get a grinder, knotch a groove in the center, get your biggest/heaviest flathead, try from there. You can try Vise-Grips. </TD></TR></TABLE>
Or use a dremal or something
Re: Stripped oil plug. (Slipjack)
get a strip bolt remover from Sears. It is like $20. Make sure you buy the metric version.
worked for my stripped bolted on the CAT.
Good Luck
Good Luck
yeah i would try the pipe wrench casue i had the same problem, and it came of in the first try. or if you have to you might have to get a bolt extractor form auto zone. and as far as gettin a new one you can get it from honda with a new crush washer for like 4 bucks, thats what i did. good luck
Re: Stripped oil plug. (tuphatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuphatt »</TD></TR><TR><TD CLASS="quote">get a strip bolt remover from Sears. It is like $20. Make sure you buy the metric version.
Good Luck</TD></TR></TABLE>
i would suggest this too. i bought a set and have never regretted it. i have taken out many stripped bolts.
Re: Stripped oil plug. (nocturnaldragon)
I just ran into the same problem. I took the pan off and drilled out the hole and welded a 3/8" pipe fititng in. (flush with inside pan) then using a 3/8 pipe plug as a drain plug
NOOdS
13
11-28-2011 02:56 PM
