ring gear holder
Re: ring gear holder (92hondalude)
When I put my ring gear on my Quaife I just took an old cut timing belt and nailed it to the leg of my shop table (4x4). Then I wrapped it around the gear about 1.5 -2 times so that when torquing the bolts the belt got tighter. It is ghetto but worked well.
Pirate
Pirate
thats the part # listed in the honda manual. so to your worthless honda dealer.
http://www.slhondaparts.com/se...se%21
07LAB-PV00100 RING GEAR HOLDER $89.64
What are you doing that you need a ring gear holder? Is the crank pulley off? If not, use the crank bolt to prevent the flywheel from turning.
i usually use a long angle iron with 2 holes drilled in it, so i bolt the angle iron to the flywheel with a pair of pressure plate bolts. that way i i have great levereage for breaking the flywheel bolts loose.
police vehicle tech
21
11-15-2009 08:12 AM
