CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!!
Old 01-05-2005, 04:38 PM
swiftstyles's Avatar
Default CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!!
like the topic states. I see alot of EG, DC etc but not alot of clean DA engine bays. Need some ideas on wire tucking!
Old 01-05-2005, 04:46 PM
stormy's Avatar
Default Re: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!! (swiftstyles)
autopilots thread is still pretty current
Old 01-05-2005, 06:23 PM
Default Re: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!! (sans)
clean, how do they tuck in all the vaccum lines?
Old 01-05-2005, 06:27 PM
stormy's Avatar
The Xsi has far fewer BS going on to begin with
Old 01-05-2005, 06:51 PM
Heres my f#*$ up lookin engine bay, what can I do to make it look better, besides painting the valve cover and probably ss header with out the heatshield. What do I do with the cluster of **** around the brake booster area? Oh and all the red hoses and coupling will have to go also!
Old 01-05-2005, 06:59 PM
stormy's Avatar
you can ditch the ABS setup for pretty cheap usually I did my old one for about 80 bux including 3 stainless lines. also clean it and pick up a AEBS IM for it or S2 for a lil less power but cleaner look. also the coolant lines that run through the TB and IACV can all be deleted. Move the battery into the trunk. Pull the fenders and rerun the wires for the headlights ect. Also pull your mounts and have them repowdercoated black . Run your ground from the back of the valvecover along another line. Also ditch the oil cap for a stock one, put your wire cover back on an repaint your valvecover as stripping it will blead heat into the engine bay. also get some stock black spark plug wires.
check g2ic.com for details
Old 01-05-2005, 07:31 PM
whiteNtegra's Avatar
my baby
Old 01-05-2005, 07:38 PM
dohcroc's Avatar
Default Re: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!! (whiteNtegra)
ur missing the intake
Old 01-05-2005, 07:41 PM
Default Re: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!! (dohcroc)
little broke after it was all finished.. new one coming soon.. just need to get paid
Old 01-05-2005, 07:50 PM
sloweg6's Avatar
very clean
Old 01-05-2005, 07:56 PM
DENCIO's Avatar
Default Re: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!! (sloweg6)
http://g2ic.com/forums/showthr...e+bay
Old 01-05-2005, 08:14 PM
Ekizzle's Avatar
Default Re: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!! (DENCIO)
<FONT SIZE="10">NICEST DA EVER !!!!</FONT>
Old 01-05-2005, 08:17 PM
jdm420da6's Avatar
good link...solved my prob with the fuse box
Old 01-05-2005, 10:48 PM
@ries's Avatar
Default Re: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!! (Ekizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekizzle &raquo;</TD></TR><TR><TD CLASS="quote"><FONT SIZE="10">NICEST DA EVER !!!!</FONT>
hell yea! good find neems. J's DA had a lot of blood, sweat, and tears put into that bay.
Old 01-05-2005, 10:49 PM
K.F14's Avatar
Default Re: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!! (@ries)
DAs are the win
Old 01-06-2005, 12:33 AM
importdude2000's Avatar
someone find max's engine..over at g2ic..
e-da9..
his **** is crazy
Old 01-06-2005, 12:37 AM
Default Re: (importdude2000)
if any of these pictures are yous pm me ill take em off
dannyboy from g2ic..
E-DA9 "the mango" from g2ic
quickda6 from g2ic
Old 01-06-2005, 12:59 AM
t . b o z's Avatar
Default Re: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!! (unChilled Euphoria)
what all is needed to delete ABS? I hate how it gets in the way of everything, just plain looks fugly!! Im guessing I need a proportioning valve and some more lines? Also, do I just remove that funky looking pump on the crossmember too?
Old 01-06-2005, 09:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteNtegra &raquo;</TD></TR><TR><TD CLASS="quote">
my baby</TD></TR></TABLE>
http://www.team-integra.net/fo...ion=1
Old 01-06-2005, 09:48 PM
WhoisDan's Avatar
Default Re: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!! (importdude2000)
Old 01-06-2005, 09:56 PM
stormy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.team-integra.net/fo...ion=1</TD></TR></TABLE>
there is some questionable info there but simply stating pipe length as a general for VE is falling into hype also some filters like mine come in a long neck version which actually makes considerably less turbulence at the TB than an any other intake pipe ect would given the 6in straight line.
Old 01-06-2005, 10:50 PM
plusONE jboy's Avatar
no kidding.
Old 01-06-2005, 10:51 PM
JDMish's Avatar
Default Re: (j boy)
some nice engine bays i wanna see more
Old 01-06-2005, 11:29 PM
Rod.'s Avatar
Default Re: (JDMish)
i love hidden wires.. i wish i had time to do it
Old 01-07-2005, 08:12 AM
GSaargh's Avatar
great thread... quickda6 is my hero!
Quick Reply: CLEANEST DA ENGINE BAY W/ WIRE TUCKED REQUEST!!
