FAQ B series torque specs
Old 08-09-2004, 03:15 AM
BlueShadow's Avatar
Default FAQ B series torque specs
Hey guys,
I just got done again compiling a list of things that I will be torqueing down while I assemble my motor and do my swap. I'll have a FSM handy, but I dont wanna be flipping through pages looking for torque specs, so I got all the numbers beforehand and put them in a word document.
I figured I'd go ahead and share them with you guys. This is right out of the 94+ Integra FSM and the 90-93 Teg FSM.
EDIT: I've updated the list to let you guys know what year/model the specs are applicable to. These are all the specs I got out of the 94+ Teg, 90-93 Teg, 89-91 Civic/CRX VTEC supplement FSM, and my 84-91 USDM Haynes manual. The only number I got from the Haynes though was the Civic/CRX fuel banjo bolt and service bolt specs.
CYLINDER HEAD BOLT TORQUE SPECS (tightening) / (loosening)
8, 4, 2, 6, 10 <---intake order 3, 7, 9, 5, 1
7, 3, 1, 5, 9 <---exhaust order 4, 8, 10, 6, 2
Torque in steps: 22ft-lbs (264in-lbs), Then to 63ft-lbs (756in-lbs) (final spec) 94+ Teg
Torque in steps: 22ft-lbs (264in-lbs), Then to 61ft-lbs (732in-lbs)(final spec) 90-93 Teg / B16's
CAMSHAFT COVER SPECS
13, 9, 5, 1, 3, 7, 11 (side of cam cover closest to intake)
14, 10, 6, 2, 4, 8, 12 (side of cam cover closest to exhaust)
Shown above is one cam cover, sequence is the same for intake and exhaust cam cover.
#1-10 20ft-lbs (240in-lbs) #11-14 7.2ft-lbs (86in-lbs) (94+ B18C specs)
#1-10 16ft-lbs (192in-lbs) #11-14 8ft-lbs (96in-lbs) (B16A specs)
**not sure what the specs are for non-VTEC motors, sorry**
Seat each camshaft by pushing it towards the dizzy side of cylinder head.
VALVE COVER SPECS
7<FONT COLOR="white">______________</FONT>5<FONT COLOR="white">______</FONT>(Intake side of valve cover)
<FONT COLOR="white">_____</FONT>3<FONT COLOR="white">____</FONT>1<FONT COLOR="white">____</FONT>
<FONT COLOR="white">_____</FONT>4<FONT COLOR="white">____</FONT>2<FONT COLOR="white">____</FONT>
8<FONT COLOR="white">______________</FONT>6<FONT COLOR="white">______</FONT>(Exhaust side of valve cover)
7.2 ft-lbs (86in-lbs) (all B series)
FLYWHEEL TORQUE SPECS
<FONT COLOR="white">_______</FONT>1
<FONT COLOR="white">_____</FONT>6<FONT COLOR="white">___</FONT>8
<FONT COLOR="white">___</FONT>4<FONT COLOR="white">_______</FONT>3
<FONT COLOR="white">_____</FONT>7<FONT COLOR="white">___</FONT>5
<FONT COLOR="white">_______</FONT>2
Torque in steps: 19ft-lbs (228in-lbs), 38ft-lbs (456in-lbs), 57ft-lbs (684in-lbs), Then to 76ft-lbs (912in-lbs) (all B series)
PRESSURE PLATE TORQUE SPECS
<FONT COLOR="white">_____</FONT>6<FONT COLOR="white">___</FONT>3
<FONT COLOR="white">_____</FONT>4<FONT COLOR="white">___</FONT>5
Torque in steps: 5ft-lbs (60in-lbs), 10ft-lbs (120in-lbs), 14ft-lbs (168in-lbs), Then to 19ft-lbs (228in-lbs) (all B series)
FUEL FILTER BANJO BOLT
25ft-lbs (300in-lbs) (94+ Teg specs)
16ft-lbs (192in-lbs) (90-93 Teg / B16 / 89-91 Civic CRX specs)
FUEL FILTER SERVICE BOLT
11ft-lbs (132in-lbs) (94+ GSR specs)
9ft-lbs (108in-lbs) (90-93 Teg / B16 / 89-91 Civic CRX specs)
HEADER A-PIPE TO B PIPE (x3)
40ft-lbs (480in-lbs) (all B series)
B PIPE TO CAT (x2)
12ft-lbs (144in-lbs) (all B series)
SHIFT LINKAGE EXTENSION ROD TO TRANNY BOLT (8x1.25mm)
16ft-lbs (192in-lbs) (90+ Teg specs)
12ft-lbs (144in-lbs) (B16 specs)
SPEED SENSOR TO TRANNY BOLT
9ft-lbs (108in-lbs)
ALTERNATOR TOP BOLT
17ft-lbs (204in-lbs) (all B series)
ALTERNATOR BOTTOM BOLT
33ft-lbs (396in-lbs) (all B series)
CRANKPULLEY BOLT
130ft-lbs (1560in-lbs) (90+ Teg)
If the crankpulley bolt is new:
145ft-lbs (1740in-lbs) loosen it a little, then re-tighten to 130ft-lbs (final spec)
87ft-lbs (1044in-lbs) (B16A, first gen)
**not sure what torque is for B16A2 and B16A3's**
TIMING BELT TENSIONER
DRIVER SIDE BRACKET TO BLOCK (x3)
DRIVERS SIDE BRACKET STUD AND BOLT
54ft-lbs (648in-lbs) (all B series)
DRIVER SIDE ENGINE TO CHASSIS MOUNT BOLT
TRANNY MOUNT TO TRANNY BOLTS (x3)
TRANNY MOUNT TO CHASSIS BOLT
REAR ENGINE BRACKET TO TRANNY BOLTS (x3)
43ft-lbs (516in-lbs) (1 passenger side) 86.8ft-lbs (1041in-lbs) (2 driver side) (94+ Teg specs)
43ft-lbs (516in-lbs) (90-93 Teg / B16 specs)
REAR ENGINE BRACKET TO MOUNT BOLT
43ft-lbs (516in-lbs) (all B series)
REAR MOUNT TO REAR SUBFRAME BOLTS (x3)
TRANNY TO BLOCK BOLTS (x5)
47ft-lbs (564in-lbs) (all B series)
LONG AND SHORT STARTER BOLTS
CLUTCH COVER LOWER BOLTS (8mm)
CLUTCH COVER UPPER BOLTS (6mm)
9ft-lbs (108in-lbs) (all B series)
INTERMEDIATE SHAFT TO BLOCK BOLTS (x3)
28ft-lbs (336in-lbs) (all B series)
FRONT AND REAR STIFFENER TO TRANNY BOLT
42ft-lbs (504in-lbs) (all B series)
FRONT AND REAR STIFFENER VERTICAL BOLTS
INTAKE MANIFOLD BOLTS
EXHAUST MANIFOLD BOLTS
23ft-lbs (276in-lbs) (all B series)
BALL JOINT CASTLE NUT
LCA TO DAMPER FORK LOWER NUT
DAMPER FORK UPPER BOLT
32ft-lbs (384in-lbs)
32mm AXLE SPINDLE NUT
134ft-lbs (1608in-lbs)
OIL DRAIN PLUG
TRANNY FILL PLUG
TRANNY DRAIN PLUG
29ft-lbs (348in-lbs)) (all B series)
SPARK PLUGS
Modified by BlueShadow at 9:39 AM 8/13/2004
Old 08-09-2004, 03:34 AM
Westrock2000's Avatar
Default Re: FAQ B series torque specs (BlueShadow)
nice work with the white lines
Good post too!
Old 08-09-2004, 03:40 AM
BlueShadow's Avatar
Default Re: FAQ B series torque specs (Westrock2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westrock2000 &raquo;</TD></TR><TR><TD CLASS="quote">nice work with the white lines
Good post too! </TD></TR></TABLE>
hehehe, thanks...I didn't like how H-T wouldn't accept my spaces so I put some white underlines in to get around it.
Old 08-10-2004, 04:24 PM
LagunaSecaEG's Avatar
so all B-series motors have the same torque specs?
Old 08-10-2004, 04:28 PM
Jester88Si's Avatar
Great info for those who don't have the FSM
Mr_CRX's Avatar
I didnt even notice those at first on my laptop screen. I wondered how he made those all spaced out
Anyways, good job! This will help a lot of people out.
Old 08-10-2004, 04:33 PM
Brrraaaap!
Blaze45's Avatar
This thread rocks! Thanks!
Blaze
Old 08-10-2004, 04:36 PM
B A N N E D
kaoss_11's Avatar
Cool buddy
Old 08-10-2004, 06:57 PM
BlueShadow's Avatar
Default Re: FAQ B series torque specs (LagunaSecaEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LagunaSecaEG &raquo;</TD></TR><TR><TD CLASS="quote">so all B-series motors have the same torque specs?</TD></TR></TABLE>
When I get home in a few hours I'll check and see if I can find B16 specs, and I'll also add some of the CRX specs if they are different.
Old 08-11-2004, 01:02 AM
BlueShadow's Avatar
I just got done going through all the specs, and I broke them down by the different B series specs too.
Old 08-11-2004, 05:22 AM
crxkane's Avatar
good job, realy need this going through the process of building a motor and i have 4 different books looking at them all to see the different specs sux's, this realy helps need to keep this post bookmarked.....
Old 08-11-2004, 07:26 AM
crx2fast's Avatar
Default Re: FAQ B series torque specs (crxkane)
nice write-up. very helpfull
Old 08-13-2004, 08:32 AM
BlueShadow's Avatar
Default Re: FAQ B series torque specs (crx2fast)
Hey guys, thanks for the replies.
I just wantd to let you all know that I went ahead included the specs in INCH POUNDS as well. I used the online calculator at http://www.onlineconversion.com
Modified by BlueShadow at 10:41 AM 8/13/2004
Old 08-13-2004, 08:36 AM
APEX CRX's Avatar
good looking out
Old 05-25-2005, 12:36 AM
RATED EG's Avatar
Default Re: FAQ B series torque specs (APEX CRX)
niceeeeeeee
Old 05-25-2005, 02:28 AM
limpy's Avatar
Default Re: FAQ B series torque specs (RATED EG)
printing now... awsome definatly need to go to the faq section... vap take care of it.
Old 11-06-2005, 04:20 PM
transpar_nt's Avatar
this just saved my ***
Old 11-06-2005, 04:55 PM
31flavorscivic's Avatar
Default Re: FAQ B series torque specs (transpar_nt)
Planning an ls/vtec over here, so if I ever get that off the ground *saves to hard drive*
Old 04-08-2006, 09:19 PM
4gencivicef9's Avatar
oil pump , water pump do you have the specs for these
Old 05-26-2006, 12:46 PM
HT White Ops
SD_Lurker's Avatar
sweet
Old 05-26-2006, 01:45 PM
ludesrv's Avatar
Nice. Bookmarked.
Old 12-16-2006, 10:40 AM
DRAG_WORKX's Avatar
Old 12-20-2006, 01:47 PM
HT White Ops
SD_Lurker's Avatar
sweet thread!
Old 12-20-2006, 01:48 PM
Pirate General...YARRRR
Ass$nyper's Avatar
holy **** you need a thank you much PM user Tyson and ask him to pop this in the FAQ v2 he helped put together.
It would benifit a ton of us
again
Old 12-20-2006, 02:26 PM
ludesrv's Avatar
Default Re: FAQ B series torque specs (Capt. Blonde Beard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Capt. Blonde Beard &raquo;</TD></TR><TR><TD CLASS="quote">holy **** you need a thank you much PM user Tyson and ask him to pop this in the FAQ v2 he helped put together.
again </TD></TR></TABLE>
It's already in there.
Quick Reply: FAQ B series torque specs
