1998 Honda Accord Ex... Keyless entry probs
All of a sudden my keyless entry will unlock and pop the hood, but not lock, it is the original factory installed system.
Re: 1998 Honda Accord Ex... Keyless entry probs (angcurdy)
uhhh. pop the hood?!?!? You mean the trunk right? lol
You might just need to get either the remote reprogrammed or to purchase a new remote...
Re: 1998 Honda Accord Ex... Keyless entry probs (rjr162)
Yup, I meant trunk...(sometimes the blonde shines through). Yeah when it cools off I was going to go outside and try to reprogram my remotes. If that doesnt work, I was going to buy new ones. I just hope it isnt anything in the car. I would hate to have to replace anything in there.. Could the battery being low have anything to do with it? (car battery)
doubtful. If it was the car's battery, then none of the functions would work.
It's something in your unit its self or the remote
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angcurdy »</TD></TR><TR><TD CLASS="quote">Yup, I meant trunk...(sometimes the blonde shines through). Yeah when it cools off I was going to go outside and try to reprogram my remotes. If that doesnt work, I was going to buy new ones. I just hope it isnt anything in the car. I would hate to have to replace anything in there.. Could the battery being low have anything to do with it? (car battery) </TD></TR></TABLE> I do not think its the remote. its unlocking , and trunk is working , I think its the lock relay, to test, switch relays, if it starts locking and not unlocking you have found problem. 94
Re: 1998 Honda Accord Ex... Keyless entry probs (fcm)
my thinking is the contacts or something else within the unlock switch on the remote's board its self is bad.
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 »</TD></TR><TR><TD CLASS="quote">my thinking is the contacts or something else within the unlock switch on the remote's board its self is bad. </TD></TR></TABLE>The "switch" is a relay, and if there are 2 relays like most Hondas you can just switch them and see if that is the problem, if it is a one unit with two relays in it or they are on a pc board inside a keyless mod. ,it can still b checked , you just have to open the relay pack or mod. and and trigger relay with jumper wire . 94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">The "switch" is a relay, and if there are 2 relays like most Hondas you can just switch them and see if that is the problem, if it is a one unit with two relays in it or they are on a pc board inside a keyless mod. ,it can still b checked , you just have to open the relay pack or mod. and and trigger relay with jumper wire . 94</TD></TR></TABLE>
I know what you're talking about, but I doubt that's something they're gonna wanna do. I know the Civic's keyless has the relays built onto a board in a white unit down in the kick panel... but they are soldered on and unless you have a decent knowledge of electronics you're most likely not going to want to mess with that though.
Pretty much it looks like unless you know someone who doesn't mind working with stuff like that you might have to take it to a shop.
well this morning it was all of a sudden working... PERFECTLY.. LOL
i figure it is one of two things.. a cell phone tower a block away.. or the space center 15 miles away.. maybe messed the signal up.. who knows..
oh and thank you all for the advice.. i like having a place to go to ask stuff about my car!!
