Speedmaster SM058... gunmetal polished, "Black Racing" style!
Speedmaster SM058... gunmetal polished, Black Racing style!
We are able to offer these wheels at a stupendous deal! The come in 15x7. 4 hole patterns are +31, and 5 hole patterns are +38! These offsets are ideal for the widest possible track on your Honda. Wider is better, right?
4x100
4x114
5x100
5x114
Get them now for only $380 shipped for the set!
Marcus
Modified by MrHeeltoe at 1:22 PM 6/29/2004
Re: (Skeletor)
They are fairly wide on the car...they poke out almost all the way to the fenders.
With a little camber and stiff suspension, you should not have an issue with rubbing on them. I have run up to a 27mm offset on my DA and I did not have any problems in the front. 30mm in the back had a little rub occasionally.
Re: (MrHeeltoe)
what is this? White? Black? 17"?
15x7
8 lug is +31
5 lug is +38
Gunmetal polished ony, just like the pic....
I think you ghuys are thingking about SM046........these are SM058
15x7
8 lug is +31
5 lug is +38
Re: Speedmaster SM058... gunmetal polished, Black Racing style! (MrHeeltoe)
Yeah, they look like "Blakc Racing" wheels...I see where the miscommunication was made....
I added another pic to the first post also....
Re: (MrHeeltoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrHeeltoe »</TD></TR><TR><TD CLASS="quote">They are fairly wide on the car...they poke out almost all the way to the fenders.
With a little camber and stiff suspension, you should not have an issue with rubbing on them. I have run up to a 27mm offset on my DA and I did not have any problems in the front. 30mm in the back had a little rub occasionally.</TD></TR></TABLE>
How stiff?!? Did you cut the fenders? Just doing some reading people are rubbing with a 35 and 38 offset, and these are a 31? Man I'd really like to mount my Azenis on them but I'm not up for body work. Bumperz for you.
Re: (Skeletor)
I'll buy these in a heartbeat if they weren't so wide. So your saying, if I mounted 205/50 Azenis on them, they will most likely rub?
Got any pics on a EG?
Re: Speedmaster SM058... gunmetal polished, Black Racing style! (legendarysleeper)
Taiwan made, and they are cast.
I cannot guarantee they would not rub, I can oly say what I had...also, I was running 195-50-15.
Marcus
Marcus
Re: (JDMCRXDelSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRXDelSol »</TD></TR><TR><TD CLASS="quote">15.4 pounds..If i'm correct.
I would like to see more pics of these masterpieces on some eg/ek</TD></TR></TABLE>
Some people with EG and EK have to take some pcs first and post them....I do not have any more pics at the moment.......
Re: (tunedbylorange.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedbylorange.com »</TD></TR><TR><TD CLASS="quote">looks like a good deal..if those things were not so heavy we'd be all over it</TD></TR></TABLE>
Same here looking for some light 15x7 like my SSR Comp's to put R compound on
Re: (9psiTurboSI)
Light and cheap are not always hand in hand.....these wheels are low priced becasue of the weight.
If they were 12 lbs like they were supposed to be, they would be more money.
Re: (MrHeeltoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrHeeltoe »</TD></TR><TR><TD CLASS="quote">Light and cheap are not always hand in hand.....these wheels are low priced becasue of the weight.
If they were 12 lbs like they were supposed to be, they would be more money.</TD></TR></TABLE>
True
True
