Brembo OE Brake Rotors (aka Brembo "Blanks") - LOWEST PRICING, FREE SHIPPING!!! - Honda-Tech
Old 01-21-2010, 02:45 PM   #1
Default Brembo OE Brake Rotors (aka Brembo "Blanks") - LOWEST PRICING, FREE SHIPPING!!!
Brembo OE "blank" rotors offer better performance than Cross-drilled rotors. Cross-drilled rotors might look "cool", but what are they really doing for performance? Brake rotors were first "drilled" in the 40's and 50's because early brake pad materials gave off gasses when heated to racing temperatures, which is called "gassing out". These gasses then formed a thin layer between the brake pad face and the rotor, effectively lowering the coefficient of friction. The "cross drilled" holes were implemented to give the gasses a place to escape. Todays brake pad materials do not exhibit the same gassing out problems as these early (old) pads. Also, there are many companies that sell "cheap" cross-drilled and slotted rotors. They do this by purchasing Brembo blanks and having them cheaply altered by a third party. Doing this sacrifices the rotors structural integrity, and can be a huge safety risk. If you contact Brembo, they will not recognize these discs after they have been altered. These rotors are known to crack and warp very quickly. If you want the actual Brembo cross drilled and slotted rotors you will be paying much more. That's why these blanks are perfect; they perform better, do not tear through pads, are priced much lower, and are much safer. Get yourself a set today!
These are THE lowest prices you will find on Genuine Brembo rotors anywhere! We have all of these in stock and ready to ship!
-Rotors are priced PER PAIR (Left & Right sides).
-Free Shipping within the Continental USA. (For Alaska, Hawaii, Canada, and other destinations, please ask us for a shipping quote)
ACURA
Year | Model | Pricing: Front, Rear
97 2.2 CL - $83 (Front Pair),$73 (Rear Pair) - Full Set (F&R) $144
97 3.0 CL - $88 (Front Pair), $73 (Rear Pair) - Full Set (F&R) $159
98-99 2.3 CL - $79 (Front Pair), $77 (Rear Pair) - Full Set (F&R) $154
98-99 3.0 CL - **Ask** (Front Pair), $77 (Rear Pair)
01-03 3.2 CL - $118 (Front Pair), $105 (Rear Pair) - Full Set (F&R) $220
86-89 Integra - $82 (Front Pair), $59 (Rear Pair) - Full Set (F&R) - $130
90-01 Integra (4-lug, excludes Type-R) - $75 (Front Pair), $64 (Rear Pair) - Full Set (F&R) $130
97-01 Integra Type-R (5-lug) - $92 (Front Pair), $78 (Rear Pair) - Full Set (F&R) $169
91-92 Legend Coupe - $92 (Front Pair), $90 (Rear Pair) - Full Set (F&R) $168
93-95 Legend Coupe - **Ask** (Front Pair), $90 (Rear Pair)
91-95 Legend Sedan (exc. GS) - $92 (Front Pair), $90 (Rear Pair) - Full Set (F&R) $168
94-95 Legend Sedan (GS) - **Ask** (Front Pair), $90 (Rear Pair)
01-06 MDX - $118 (Front Pair), $145 (Rear Pair) - Full Set F&R $260
91-96 NSX - $199 (Front Pair), $159 (Rear Pair - Full Set F&R $355
97-05 NSX - **Ask**
02-06 RSX Type-S - $125 (Front Pair), $78 (Rear Pair) - Full Set F&R $200
02-06 RSX (base) - $75 (Front Pair), $78 (Rear Pair) - Full Set F&R $151
95-98 2.5 TL - $112 (Front Pair), **Ask** (Rear Pair)
96-98 3.2 TL - $92 (Front Pair), **Ask** (Rear Pair)
99-03 TL - $118 (Front Pair), $88 (Rear Pair) - Full Set (F&R) $205
04-06 TL A/T & Standard Front Calipers - $118 (Front Pair), $88 (Rear Pair) - Full Set (F&R) $205
04-06 TL M/T & Brembo Front Calipers - **Ask** (Front Pair), $88 (Rear Pair)
07 TL (excluding Type-S) - $118 (Front Pair), $88 (Rear Pair) - Full Set (F&R) $205
07 TL Type-S - **Ask** (Front Pair), $88 (Rear Pair)
04-08 TSX - $110 (Front Pair), $90 (Rear Pair) - Full Set (F&R) $190
HONDA
90-94 Accord (excludes Wagon) - $83 (Front Pair), $73 (Rear Pair) - Full Set (F&R) $154
90-94 Accord (Wagon) - $88 (Front Pair), $83 (Rear Pair) - Full Set (F&R) $159
95-97 Accord (V6 and Wagon) - $88 (Front Pair), $73 (Rear Pair) - Full Set (F&R) $159
95-97 Accord (4 cyl. excludes Wagon) - $83 (Front Pair), $73 (Rear Pair) - Full Set (F&R) $154
98-02 Accord (4 cyl w/ Rear Disc) - $79 (Front Pair), $77 (Rear Pair) - Full Set (F&R) $154
98-02 Accord (4 cyl w/ Rear Drum) - $79 (Front Pair), $145 (Rear Pair) - Full Set (F&R) $222
98-02 Accord V6 - $99 (Front Pair), $78 (Rear Pair) - Full Set (F&R) $175
03-04 Accord w/ Rear Disc - $99 (Front Pair), $95 (Rear Pair) - Full Set $192
03-04 Accord w/ Rear Drum - $99 (Front Pair), $119 (Rear Pair) - Full Set $216
05-07 Accord w/ Rear Drum - $99 (Front Pair), $119 (Rear Pair) - Full Set $216
05-07 Accord w/ Rear Disc (excluding V6 Coupe w/ 6spd M/T & Hybrid) - $99 (Front Pair), $95 (Rear Pair) - Full Set $192
05-07 Accord V6 Hybrid - $118 (Front Pair), **Ask** (Rear Pair)
05-07 Accord V6 Coupe w/ 6spd M/T - $118 (Front Pair), $95 (Rear Pair) - Full Set (F&R) $210
88-89 Civic (all) - $82 (Front Pair),**Ask** (Rear Drums)
90-91 Civic (all, excluding EX Sedan) - $78 (Front Pair), **Ask** (Rear Drums)
90-91 Civic (EX Sedan) - $75 (Front Pair), **Ask** (Rear Drums)
92-95 Civic (all, excluding EX, SI w/ ABS, LX w/ ABS) - $78 (Front Pair), $64 (Rear Pair) - Full Set F&R $134
92-95 Civic (EX, SI w/ ABS, LX w/ ABS) - $75 (Front Pair), $64 (Rear Pair) - Full Set (F&R) - $130
96-00 Civic (all, excluding EX and SI) - $78 (Front Pair), **Ask** (Rear Drums)
96-00 Civic EX - $75 (Front Pair), **Ask** (Rear Drums)
99-00 Civic SI coupe - $75 (Front Pair), $64 (Rear Pair) - Full Set (F&R) - $130
01-05 Civic (excluding Si hb) - $75 (Front Pair), **Ask** (Rear Drums)
02-03 Civic Si HB - $75 (Front Pair), **Ask**
04-05 Civic Si HB - **Ask** (Front Pair), $78 (Rear Pair)
06-07 Civic Si (Coupe & Sedan) - $175 (Front Pair), **Ask** (Rear Pair)
97-01 CR-V - $92 (Front Pair), $127 (Rear Pair) - Full Set (F&R) $215
02-04 CR-V - $99 (Front Pair), $88 (Rear Pair) - Full Set (F&R) $185
05-06 CR-V - $175 (Front Pair), **Ask** (Rear Pair)
84-87 CRX (all) - $55 (Front Pair), **Ask* (Rear Drums)
88-89 CRX (DX, SI) - $82 (Front Pair), **Ask* (Rear Drums)
88-91 CRX (HF) - $55 (Front Pair), **Ask* (Rear Drums)
90-91 CRX (Base) - $78 (Front Pair), **Ask** (Rear Drums)
90-91 CRX (SI) - $82 (Front Pair), $64 (Rear Pair) - Full Set (F&R) $131
93-97 Del Sol S w/ Rear Drum - $78 (Front Pair), **Ask* (Rear Drums)
93-97 Del Sol Si w/ Rear Disc - $78 (Front Pair), $64 (Rear Pair) - Full Set (F&R) $134
94-97 Del Sol VTEC (DOHC) - $75 (Front Pair), $64 (Rear Pair) - Full Set (F&R) $130
03-07 Element - $118 (Front Pair), $95 (Rear Pair) - Full Set (F&R) $210
07-10 Fit - $75 (Front Pair), **Ask* (Rear Drums)
00-06 Insight - $55 (Front Pair), **Ask* (Rear Drums)
10-12 Insight - $75 (Front Pair), **Ask* (Rear Drums)
92-96 Prelude (S, SI) - $100 (Front Pair), $95 (Rear Pair)
93-96 Prelude (VTEC) - $88 (Front Pair), $95 (Rear Pair)
97-01 Prelude - $92 (Front Pair), **Ask** (Rear Pair)
00-07 S2000 - **Ask**
How To Order-
We accept Visa, Mastercard, American Express, Diners Club, Discover, and JCB
Online
Go to our website, CLICK HERE and add the Brembo rotors to your cart that you want. When checking out your order in the "Notes" section type in "HONDA-TECH DISCOUNT" and we'll edit the order total after you place it and you'll be charged the correct discounted amount!
Phone Orders
Give us a call at 1-888-378-7278. We're open all day Monday-Friday to take your orders over the phone!
Paypal
All Paypal payments must be sent to: paypal@importrp.com
Money Order/Cashiers Checks:
Contact us for details on payment this way. E-mail us at: sales@importrp.com
Have A Question?
Send us a PM or Post to this Thread. Or E-mail us at: sales@importrp.com or call at 1-888-378-7278. We're open all day Monday-Friday and answer emails 7 days a week.
Import RP is offline   Reply With Quote
Old 01-22-2010, 05:25 PM   #2
Default Re: Brembo OE Brake Rotors (aka Brembo "Blanks") - LOWEST PRICING, FREE SHIPPING!!!
Unbeatable deals, let me know what you guys need :D
Old 01-22-2010, 10:43 PM   #3
diogolucindo's Avatar
Hi! Do you have a brembo brake pads to sell with the rotors? Whats the price for a full kit(front+rear), rotors+pads for:
Thanks
diogolucindo is offline   Reply With Quote
Old 01-25-2010, 05:09 PM   #4
Thanks
Brembo doesn't make any pads any longer for Hondas, so you'd need to go with another brand. The best bang for the buck pads are the PBR/Axxis pads. We have great deals on those. We also sell other popular brands like Hawk, EBC, Akebono, and more too. Which pads would you be interested in?
Thanks,
Mike
Old 01-26-2010, 08:40 AM   #5
ketchup!'s Avatar
hmmm my 95 civic ex has a rear disc conversion with no abs. and i can't find the rear rotors for my car what should i do?
ketchup! is offline   Reply With Quote
Old 01-26-2010, 08:46 AM   #6
ketchup!'s Avatar
Quote:
Thanks,
Mike
what pads would you recommend. mainly street driven car
Old 01-26-2010, 01:52 PM   #7
Quote:
Just use the same rear rotors as the 92-95 Civic SI, it's exactly the same.
Old 01-26-2010, 01:54 PM   #8
I would recommend the PBR/Axxis Metal Master (XBG) Pads for a good street pad with more performance. If you want something closer to stock, get the PBR/Axxis Deluxe Advanced Pads.
Old 01-27-2010, 04:25 PM   #9
All of today's PM's replied, thanks guys!! :-D
Old 01-27-2010, 04:29 PM   #10
1. Price for some rear brembo blanks for nissan 300zx to 92704.
2. Also even better if you could a set or rear nissan 300zx SLOTTED rotors to 92704.
3. Front and rear brembo blanks for 2000 Accord Coupe 4cylinder to same address.
Pm me please.
Thanks,
John
tranjq is offline   Reply With Quote
Old 01-28-2010, 09:12 AM   #11
Pm me please.
Thanks,
John
Sent you a PM.
Old 01-29-2010, 03:56 PM   #12
All PM's are replied
Old 01-31-2010, 01:16 AM   #13
Gr1m_ReApeR's Avatar
Hey im looking for some new front rotors along with some PBR/Axxis pads for a 00 Civic Dx
Can you please Pm me a price shipped to 92553
Gr1m_ReApeR is offline   Reply With Quote
Old 02-01-2010, 12:55 AM   #14
MadLorGLK's Avatar
pm sent
MadLorGLK is offline   Reply With Quote
Old 02-02-2010, 05:11 PM   #15
Gr1m_ReApeR - Sending you a PM now
MadLorGLK - PM replied
Old 02-03-2010, 03:26 AM   #16
EG6666's Avatar
payment sent!
EG6666 is offline   Reply With Quote
Old 02-04-2010, 09:12 AM   #17
Quote:
Originally Posted by EG6666 View Post
payment sent!
Thank you!
Old 02-05-2010, 10:20 AM   #18
Thank you for your orders this week, keep the inquiries coming!
Old 02-11-2010, 10:04 PM   #19
All PM's are replied and orders shipped!
Old 02-12-2010, 07:03 AM   #20
need front rotors for 96 civic ex with some PBR/Axxis pads shipped to 06854
crist488 is offline   Reply With Quote
Old 02-14-2010, 06:17 PM   #21
Please PM price for Axxis Ultimate front and back, as well as any package deals for pads and Brembo blanks front and back. This is for a 2000 ITR.
Thank you!
walrus214 is offline   Reply With Quote
Old 02-17-2010, 04:08 PM   #22
crist488 - Sent you a PM
walrus214 - Sent you a PM too
Thanks ,
Mike
Old 02-20-2010, 04:21 PM   #23
Old 02-22-2010, 05:32 PM   #24
FAILWGN
Micha's Avatar
Looking for package price for an 04 TL 5AT.
Looking for all new brembo blanks and axxis metal masters pads shipped to 22448.
Thanks.
Micha is offline   Reply With Quote
Old 02-26-2010, 05:42 PM   #25
Thanks.
Sent you a PM
Brembo Blanks and Cobalt Pads - Integra, some civic/prelude/crx DIRep972 For Sale 7 09-05-2012 06:58 AM
D2 Racing Sports 36-way FULLY ADJUSTABLE coilovers/springs lowest pricing!!!! Unified-Forums Wheels, Tires, Brakes, and Suspension 67 03-03-2011 09:14 AM
Brembo X-drilled & slotted rotors, best prices, guaranteed! 88ROTORS Wheels, Tires, Brakes, and Suspension 557 12-03-2008 03:43 PM
88ROTORS Performance Cross-drilled & Slotted brake rotors 88ROTORS Performance 121 10-29-2008 02:48 PM
F&R tire combos? jspexae102 Road Racing / Autocross & Time Attack 5 02-28-2005 02:10 PM
Tags
06, 2000, acura, blank, blanks, brake, brembo, civic, front, oe, pads, rear, rotor, si, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
