>>>Brake Pads, Lines & Rotors<<< NoLimitMotorsport.com - Honda-Tech
Old 08-08-2013, 09:22 AM   #1
Default >>>Brake Pads, Lines & Rotors<<< NoLimitMotorsport.com
Please PM, email, or Call for SPECIAL HT PRICING!!!!!
Email: chris@NoLimitMotorsport.com
Brake Pads
Stock brake pads are fine for the average driver. However, the driving enthusiast looking to enhance their car's brake performance has several choices. Compared to stock brake pads, performance brake pads generate more friction and work in a broader range of temperatures while reducing the possibility of brake fade at higher temperatures. Higher performing brake pads continue to work in an even higher range of temperatures and further reduce the possibility of brake fade.
brands: Hawk, EBC
Hawk
Hawk Performance HPS Performance Street Brake Pads
Hawk Performance HP Plus Brake Pads
Hawk Performance HT-10 Brake Pads
Hawk Performance DTC-30 Brake Pads
Hawk Performance DTC-60 Brake Pads
Hawk Performance DTC-70 Brake Pads
Project Mu
B Spec
HC-CS
HC+
RACING-N1
RACING-N+
EBC
EBC Greenstuff Brake Pads
EBC Redstuff Brake Pads
BC Yellowstuff Street and Track Brake Pads
PM ME FOR SPECIAL HONDA-TECH PRICING!
Rotors
While changing brake pads may come as common sense upgrading or replacing rotors is often neglected. The pressure and heat generated by the brake pads rubbing against the brake rotors combined with the dirt and debris that gets between them wears away metal, slowly removing the material that was designed to act as a heat sink to maintain braking performance and efficiency. Once brake rotors have worn to their minimum thickness it’s time to replace them.
brands: Stop Tech, PowerSlot, DBA, EBC
PowerSlot
Power Slot Slotted Brake Rotor
Power Slot Cryo Slotted Brake Rotor
DBA
DBA Street Series Slotted Brake Rotor
DBA Street Series Gold Brake Rotor (Cross-Drilled & Slotted)
DBA 4000 Series Brake Rotor (6x6 Wiper-Slot)
DBA 4000 Series XS Brake Rotor (Premium Cross-Drilled & Slotted)
EBC
EBC Stock Replacement Rotors
EBC Sport Rotors
EBC Ultimax Rotors
Brake Lines
Stainless steel braided brake lines are an industry standard in the world of motor racing. These kits feature the finest quality stainless steel braided hose, which improves braking performance, eliminates the spongy feel of rubber hoses and provides superior resistance to corrosion.
Acura Brake Lines
Honda Brake Lines
Brake Fluid
Motul RBF600
Motul RBF 5.1
NoLimitMotorsport is offline   Reply With Quote
Old 08-08-2013, 02:22 PM   #2
Default Re: >>>Brake Pads, Lines & Rotors<<< NoLimitMotorsport.com
bump
Old 08-09-2013, 08:04 AM   #3
casual friday
Old 08-09-2013, 01:08 PM   #4
bump
Old 08-10-2013, 08:59 AM   #5
bump
Old 08-13-2013, 08:11 AM   #6
bump
Old 08-14-2013, 09:58 AM   #7
hump day
Old 08-14-2013, 02:32 PM   #8
bump
Old 08-15-2013, 09:13 AM   #9
bump
Old 08-15-2013, 10:30 AM   #10
bump
Old 08-15-2013, 02:09 PM   #11
bump
Old 08-16-2013, 08:53 AM   #12
bump
Old 08-16-2013, 10:30 AM   #13
bump
Old 08-17-2013, 07:50 AM   #14
bump
Old 08-19-2013, 07:26 AM   #15
bump
Old 08-20-2013, 08:25 AM   #16
bump
Old 08-20-2013, 11:40 AM   #17
bump
Old 08-21-2013, 07:36 AM   #18
bump
Old 08-21-2013, 11:13 AM   #19
KILE
Old 08-22-2013, 08:00 AM   #20
bump
Old 08-22-2013, 12:53 PM   #21
bump
Old 08-23-2013, 08:03 AM   #22
bump
Old 08-23-2013, 12:31 PM   #23
bump
Old 08-24-2013, 07:57 AM   #24
bump
Old 08-26-2013, 08:00 AM   #25
bump
Hawk Performance Brake Pads NoLimitMotorsport Wheels, Tires, Brakes, and Suspension 2526 02-25-2017 09:59 AM
DBA Brake Rotors in Stock! Drilled and Slotted Rotors RedlineMotive Wheels, Tires, Brakes, and Suspension 1 08-09-2011 06:18 AM
Cross Drilled VS Slotted Rotors risktypeS Acura RSX DC5 & Honda Civic EP3 29 11-30-2008 03:46 PM
Powerslot rotors + Hawk Brake Pads.. Best Prices available! VisualAutoMotoring Wheels, Tires, Brakes, and Suspension 129 03-01-2007 12:27 PM
Power Slot Brake Rotors NoLimitMotorsport Wheels, Tires, Brakes, and Suspension 1 06-28-2004 08:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
