what to do? stripped/seized lug on loose stud
Old 06-03-2011, 08:21 AM
tallblondkid's Avatar
Default what to do? stripped/seized lug on loose stud
I am switching out my wheels for a race tomorrow and one of the lug nuts strips and seizes on the stud, but then the stud gets loose and is free spinning also. in other words, they are like one piece now and spinning freely together. so I cant get the wheel off to get to the studs... what are my options?
Old 06-03-2011, 10:36 AM
Sanji
toyomatt84's Avatar
Default Re: what to do? stripped/seized lug on loose stud
Depending on how much clearance you have to the lugs themselves, I'd recommend getting a Dremel out and trying to cut the lug nut off.
Old 06-03-2011, 10:42 AM
cr125r's Avatar
drill center out of stud wheel should pop off go to local auto store and get new stud follow book for replacement of stud
Old 06-03-2011, 12:18 PM
TunerN00b's Avatar
Lug nut splitter
Old 06-03-2011, 01:38 PM
TerribleToo's Avatar
If its a rear you could pull the whole hub/rotor off. You will need to remove the caliper and destroy the grease cap to get to the nut.
Might be safer to the wheel vs a dremel.
Just a thought
Old 06-05-2011, 08:54 AM
thanks for the help guys... ended up just taking a 1/2" drill bit all the way into the stud
tallblondkid
06-05-2011 08:56 AM
eM2tK
Honda Civic (2001 - 2005)
03-09-2011 10:15 AM
kyteggy
02-05-2006 01:39 PM
ITACivic
11
04-14-2003 04:41 PM
magic hat #9
08-07-2002 07:30 PM
Quick Reply: what to do? stripped/seized lug on loose stud
