tire pressure
Old 05-27-2009, 11:16 AM
GuCBlackEk's Avatar
Default tire pressure
whats the ideal tire pressure for daily driving? 40psi?
Old 05-27-2009, 11:45 AM
TunerN00b's Avatar
Default Re: tire pressure
Sigh...
Please read the thread that tells you to read it before posting:
Forum Rules and FAQ - READ BEFORE POSTING
https://honda-tech.com/forums/wheel-tire-56/9658-forum-rules-faq-read-before-posting-1188922/
Originally Posted by Forum Rules and FAQ
What air pressure should I use in my tires?
As a general rule, regardless of wheel or tire size or type, the best place to start is with the pressure recommended for your CAR, as shown in your owner's manual and on your car either on the door jamb or glove compartment door. Measure the pressure when the car has been sitting for several hours out of the sun, at the outside temperature at which the car will be used. Adjust from there in 2 psi increments as needed, based on tire wear and your preference for handling and/or ride comfort.
Do NOT set the pressure to the maximum pressure indicated on the sidewall of your tire.
Old 05-27-2009, 11:53 AM
GuCBlackEk's Avatar
Originally Posted by TunerN00b
Sigh...
https://honda-tech.com/forums/showthread.php?t=1188922
i get that but im talking about aftermarket rims/wheels. would it be the same as stock wheel/rim setup?
Old 05-27-2009, 12:30 PM
trifenix's Avatar
yea
Old 05-27-2009, 01:21 PM
Cooper The Tire Rack's Avatar
Always follow what is recommended by your vehicle's manufacturer -- even on aftermarket wheels/tires.
If you're staying within 1-3% of the original tires size spec in terms of overall diameter, the tire size is changing, but the air chamber is staying pretty close to the original size. Think of a balloon being pressed against a table: the balloon gets wider, the profile lower, but the air chamber size remains the same. The same applies to tires.
Old 05-28-2009, 01:39 PM
DaveSi677's Avatar
I think that is one of the best answers I have heard in a long time about this specific subject!
Old 05-28-2009, 01:44 PM
I appreciate that.
mugen92acintls
03-06-2004 02:12 PM
shadowdawn
11-05-2002 11:21 AM
bhang
08-08-2002 05:48 AM
TeamTooQuick
03-13-2002 09:25 PM
Quick Reply: tire pressure
