Is there issues if one tire has a lower speed rating then my other 3? - Honda-Tech
Old 09-11-2010, 02:54 PM   #1
Icon2 Is there issues if one tire has a lower speed rating then my other 3?
Hey all,
Please help me out if you could - I need to replace a tire on my 2007 Honda Accord EX, and my tires currently have v rated tires. But there's a nail in one of my tires and I'll need to replace it. Would it be disadvantageous to have one of my tires have a H-rated tire and different from the rest? I don't drive any more than 80 mph usually, and I only drive it to work and occasional short trips to restaurants/markets. Help please?
tnywy is offline   Reply With Quote
Old 09-11-2010, 03:39 PM   #2
H-T Order of Merit
Default Re: Is there issues if one tire has a lower speed rating then my other 3?
Yes and no.
It shouldn't be a problem to use tires with different speed ratings because of their speed rating, as long as you're not exceeding the speed for the lowest speed rating you have - in this case, 130 mph for the H rating.
However, it's a bad idea to use tires that have significantly different performance characteristics from each other. For example, if you have three grand touring all-season tires, it's a bad idea to mix them with one (or more) maximum performance summer tires, because they will behave differently from each other, and this different behavior can change depending on the conditions. It can not only degrade your car's handling, but also make it unpredictable. That's why it's best to use four tires of the same make and model where possible, and otherwise to mix them only with tires in the same performance category.
nsxtasy is offline   Reply With Quote
Old 09-11-2010, 05:16 PM   #3
Thanks nsxtasy. I thought that'd be the case. I'll pay the extra to get the same performance tire then
Old 09-12-2010, 06:16 PM   #4
CountDracura's Avatar
No tire or vehicle manufacturer will ever recommend mixing speed ratings. While you wont run in to many issues with top speed stability as nsxtasy has fore mentioned, the sidewall construction does change from speed rating to speed rating. If you are forced to mix speed ratings, it is recommended to place the higher speed rated tire on the rear so as not to induce over steer on turns in inclement weather.
CountDracura is offline   Reply With Quote
Old 09-15-2010, 09:11 AM   #5
Both nsxtasy and CountDracura (nice name, btw) have good points. In a pinch, I am not against selling a pair of H-rated tires if the same tire isn't available in V-rate. But that's as low a step I am willing to take. Going from V to T or lower may cause remarkable differences in handling, lateral roll, oversteer, etc.
Cooper The Tire Rack is offline   Reply With Quote
Which tires to go with for 07? derekcentrico Honda Accord & Crosstour (2003 - Current) 3 03-12-2010 01:19 PM
Tire speed rating for Gen 4, and brand, help caliskier Honda Prelude 4 08-04-2007 08:22 PM
General Exclaim UHP Tires batguano Honda S2000 37 10-16-2006 10:08 PM
Help - Tire Pressure HondaMan78155 Honda Civic (2001 - 2005) 3 09-19-2006 07:59 PM
2001 Accord Coupe EX V6 Tires Cartman1976 Honda Accord (1990 - 2002) 3 02-05-2006 02:40 PM
Tags
accord, crv, fit, happen, honda, lower, mix, mixing, rated, rating, ratings, replace, speed, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
