Refinishing wheels: Can I use paint thinner? - Honda-Tech
Old 10-29-2005, 05:41 AM   #1
SRd240sx's Avatar
Default Refinishing wheels: Can I use paint thinner?
Ok guys I have a pair of SSR Formula Mesh that I want to refinish. The face has dirt stuck in between spokes and it's almost impossible to clean (haven't really tried to scrub that hard though). I was wondering if I could just remove the face and soak it in paint thinner for a few hours and then wash everything off?
I've used paint stripper/aircraft remover before on wheels, and it didn't turn out pretty. Maybe I didn't have enough but the clear coat/paint would come off blotchy and I couldn't exactly get EVERYTHING off. I dunno maybe I'm just a noob.
Any insight is appreciated. I would like to know the best way to refinish these. I plan on removing everything (paint, clear) and then spraying it black.
On my other Rota rims I just sanded the spokes down and sprayed it, but that would take ALOT of elbow grease since there are 1,000 spokes on these damn rims... It'd take forever to finish.... Any ideas?
These aren't mine... mine are a lot dirtier. Just for reference. TIA
SRd240sx is offline   Reply With Quote
Old 10-29-2005, 05:42 AM   #2
SRd240sx's Avatar
Default Re: Refinishing wheels: Can I use paint thinner? (SRd240sx)
Or how bout bead/sandblast?
Old 10-29-2005, 07:17 AM   #3
JDMrps13's Avatar
i would sand blast them just because its easier and you get better results.....i used aircraft remover on my stock s13 wheels.....i mean it worked but took forever.....i have access to a sand blaster so....it just makes life a lot easier......so u drive a 240 huh...got any pics......
JDMrps13 is offline   Reply With Quote
Old 10-29-2005, 12:57 PM   #4
SRd240sx's Avatar
Default Re: Refinishing wheels: Can I use paint thinner? (JDMrps13)
Hey thanks for the reply.. yeah got a 240, don't have any good pics at the moment, but planning to take some next week
What places usually have a sand blaster? Typically how much is labor per wheel?
Old 10-29-2005, 01:48 PM   #5
SRd240sx's Avatar
reason why i say paint thinner is because it's really cheap and i can just soak the face in it..
just don't know if paint thinner will really take anything off
Old 10-29-2005, 07:03 PM   #6
clean rice's Avatar
If the wheels have a clear coat over them I wouldn't even bother with paint thinner. Also I would not recommend sand blasting it either. Aluminum is soft and the sand can actually pit the aluminum, and in some cases making it weaker. I would suggest having them chemically dipped. It strips EVERYTHING, clear coat, dirt/tar, and paint. That is your best option and doesn't cost much to do. Good luck
clean rice is offline   Reply With Quote
Old 10-29-2005, 07:07 PM   #7
clean rice's Avatar
Default Re: Refinishing wheels: Can I use paint thinner? (clean rice)
Example of my MR5's before and after being chemically dipped....
And now they look like this....
check sig
Old 10-29-2005, 11:54 PM   #8
SRd240sx's Avatar
looks awesome, can you provide more info on chemical dipping?
Old 10-30-2005, 10:02 AM   #9
Royal_C!ty's Avatar
Damn, those MR5's came out righteous
Royal_C!ty is offline   Reply With Quote
Old 10-30-2005, 11:36 AM   #10
clean rice's Avatar
Quote:
Umm, I'm not really sure exactly what the chemicals are that are used. I know it doesn't weaken the aluminum or anything. Any local bead blasting/sand blasting place should offer it, and it only takes a few minutes to do. I got mine back the same day.
Old 10-30-2005, 03:16 PM   #11
SRd240sx's Avatar
Quote:
thanks for the info. how much did it cost?
Old 10-30-2005, 07:03 PM   #12
clean rice's Avatar
It was like $20 a face or somethin like that.
Old 10-30-2005, 07:19 PM   #13
SRd240sx's Avatar
wow not bad, i'll look into it, thanks alot clean rice
Old 10-30-2005, 07:30 PM   #14
clean rice's Avatar
No problem, good luck man
Had Benz AMG Monoblocks refinished/lip polished. Clear peeling off of lip. WHY??? BolivianFuego General Discussion and Debate 39 10-21-2015 08:39 AM
Build Thread: 50$ Paint Job, EF style gourley Paint and Body 316 03-27-2012 02:52 PM
How do I get paint off of my tires??? starbai Wheel and Tire 9 04-24-2008 11:01 AM
Painted rims chipping like crazy! AaronJ Honda / Acura 9 10-25-2004 11:30 AM
how to get paint off tail lights? raph Honda CRX / EF Civic (1988 - 1991) 1 03-25-2002 07:39 AM
Tags
bead, blasting, honda, jose, paint, refinish, rims, san, sand, sandblasting, thinner, tire, utech, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
