operation mesh wheel refurb
alrighty, as some of you know i came up on some mesh wheels from a buddy of mine.. .not sure of origin but they're O.Z. wheels and looked like hell when i got them.. so i'm polishing the lip and painting the mesh bronze....
<u>whats needed:</u>
sandpaper: ( i just bought it in 9x11 sheets, needed a couple of each)
150 grit (only needed for curbing and other flaws)
220 grit (will remove the grooves from the 150, if 150 not needed.. .start here)
320 grit
400 grit
600 grit
800 grit
1000 grit (optional)
1500 grit
box of latex gloves (if not, your hands will be black afterwards)
wheel paint (color of choice)
wheel clear coat
blue painters tape
wheel polish
patience
before:
here is one after being stripped of paint and steam washed..
lookin a little better here..
here is one of the lips to begin with, using the curbage as a reference point...
this is after hitting it with 150 grit, you want to do this dry sanding (again, only needed for curbage or any other flaws)
this is with 220 grit to cover the 150 grit grooves, dry sanding again
320 grit, again dry sanding
then 400 grit, dry sanding (forgot to take a pic, too busy)
now to 600 grit wet sanding, be sure to use lots of water
800 grit, wet sand.. again, water (forgot pic again, haha)
1500 grit, wet sand.. water, water, water
not too shiny yet.. how bout a little polish :D
now that the lip is nice and shiny, time to tape off the outer rim so no paint hits it.. like so..
some people use newspaper and tape it.. its a hassle and rips.. so i use all tape.. :D
time to apply paint/clear.. apply evenly (mine was difficult to do because getting in between the mesh isnt easy)......... place in sun and let it dry.. once dry, remove tape.. should look like this ..
again referring back to the curbage.. this is as good as i could get it
and here is the outcome
and now to the difference from before and after polish and paint...
oooo.. notice the shine off that lip..
that is all
Modified by eg6sir88 at 3:04 PM 9/11/2007
320 grit
400 grit
600 grit
800 grit
1500 grit
wheel clear coat
blue painters tape
wheel polish
patience
before:
that is all
Re: operation mesh wheel refurb (eg6sir88)
sick restoration
seen the other people hating in the other thread but those bad boys are some nice looking wheels. make sure you report back when you get them mounted
Re: operation mesh wheel refurb (kleen98accord)
What kind of stripper did u use? Im restoring some bbs meshes, but it is a pain because the of all the little hard to get spots in the mesh. Is there something else thats cheaper and more effective than air craft stripper, cus ive used up one can on 1 wheel and those things can get costly.
i used a spray stripper from home depot.. and the pressure washer at the spray and wash.. just cover them with the stripper.. its kinda like a gel.. let it sit for 15 min.. and pop a couple quarters in and spray the **** off..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kleen98accord »</TD></TR><TR><TD CLASS="quote">looks good. did you tape the outter rim?</TD></TR></TABLE>
yea.. i polished it then taped it off to paint the mesh
Re: (SilverDC4)
Maybe good to clear coat everything including the lip.
Wow that restoration result is very nice and almost pro looking. But how much
time was put into each rim. I tried before on just one rim that had a 10 inch curb rash and including sanding and painting, it took hours. I can't imagine how long the whole rim would take with home equipment.
Nowadays I would just get it done professionally at a rim restoration shop for a reasonable fee. But I think it is money well spent knowing all the labor involved and they can correct larger damage too. Plus for certain rims needing powder coating, I just can't do it myself at home.
it took about 2-3 hrs each wheel .. i did them on separate days so i didnt kill my forearms.. home equipment, whats that?.. you mean my arms.. ahhaa
how stupid it would it be to mount the wheel with no tire and jack the car up, then run the engine and use it as a lathe for such a job? are we talking dismemeberment here?
Do you even PLEBE R8?
Awesome job, im gonna attempt the same on a set of ls mesh wheels for my other DC4 daily driver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakedoe »</TD></TR><TR><TD CLASS="quote">how stupid it would it be to mount the wheel with no tire and jack the car up, then run the engine and use it as a lathe for such a job?</TD></TR></TABLE>
Hmm, probably wouldnt recommend it but good effort
Re: operation mesh wheel refurb (ForceFed_Motorsports)
They came out real nice
Still wondering why some people polish first then paint, while others paint then polish....
A handy tool for sanding the lips would be the tiny sanding block with handle (3M) sold at home depot. That way you can EAT after you done with the job. I couldn't feel/move my fingers after trying to do this by hand under cold weather.
